water in spare tire well
I apparently have a leak somewhere resulting in water getting in my spare tire well. The carpeting 'up top' in the rear hatch area is dry.
It does appear to be sourcing towards the back of the car - perhaps from under the plastic, and was wondering if it's leaking around the tail lights.... I don't see anything to indicate it's coming from the hatch seal.
Anybody have experience with this?
98 RS
98 RS
check the tube connected from yoru antenna, and the tube coming from your sunroof (if you have one). These areas are known entry points for water coming into your wheel well.
so, some more data and another question:
1) yesterday, rain, listened to radio (i.e., antenna up), water in spare wheel well.
2) today, rain, did NOT listen to radio (i.e., antenna down), NO water in spare wheel well.
$64,000 Q: Does the antenna only leak when up? :-)
i had the same problem and it was my tailights
also a lil advice if it got to the point were mold started growng just fixe it dry out your trunk and spray the cardboard pice and carpet with lysol. It works awsome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed »</TD></TR><TR><TD CLASS="quote">If its coming from the taillights. I make taillight gaskets for third gen integras. Half the price of the dealer cost. </TD></TR></TABLE>
Vouch for ragejed. Good seller.
I was getting water in my taillight area and ragejed's gaskets fixed the problem
Nice quality too
Nice quality too
I agree with the taillights. I have a 99 ek hatch, and everyone who I ask with a 96 ek hatch has the same problem. Forget the gaskets. Man those things are expensive. Do what I did and drill numerous holes in your spare trunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr »</TD></TR><TR><TD CLASS="quote"> Forget the gaskets. Man those things are expensive. Do what I did and drill numerous holes in your spare trunk.</TD></TR></TABLE>
$25 is not expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">
agreed. plus i'd rather buy those than drill holes in my car
</TD></TR></TABLE>agreed. plus i'd rather buy those than drill holes in my car
15 year old thread.
Take the old spongy black gasket to a arts & crafts store and ask someone where that craft material is located.
It's a couple of bucks each sheet and you can cut your own.
If you wish to remove it, I'd use gasoline and a plastic scraper.
In my opinon the tailight gasket isn't just to blame for the water leak in spare tire well. There was water on the butt support of the rear passenger seat. Seats were already removed since I need to change the fuel pump.
Some are saying sunroof drain.
I was at the junkyard the other day and noticed a 1" OD tube on both sides of the Integra.
Again, if the tail light gasket were to solely to blame for this, then the carpet would be soaking wet/smelly for a long while. Had to throw away the OEM scissor jack because of this nuisance.
Edit: I went ahead an put silicone tape and zip tie, on both sides of the car.
Code:
https://i.imgur.com/V98Wfib.jpg
Code:
https://i.imgur.com/m4DTpdH.jpg
F120man
13
Nov 30, 2005 05:03 AM
