Where can I get new 75mm (STD) ZC Pistons?
You want p29 88-89 integ pistons (zc) not the 86-87 there is a big difference.88-89 are domed and 86-87 are flat. If you want the ZC piston you are looking for the PM7. The ZC piston and the 88-89 integra p29 pistons are the same. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanR »</TD></TR><TR><TD CLASS="quote">Sure, there's a shop called the Acura dealership that carries them. 88-89 Integra pistons.</TD></TR></TABLE>
I've purchased these before. There is a difference. The ZC pistons have the skirts coated like the ITR and the domw is a tad higher I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">I've purchased these before. There is a difference. The ZC pistons have the skirts coated like the ITR and the domw is a tad higher I believe.</TD></TR></TABLE>
I don't know about the coating... But, compression wise, the 88-89 D16a1 pistons are the same as the ZC. The compression on the 86-87 D16a1 pistons are .2 lower then the 88-89. The 86-87 connecting rods are stronger though.
crxnug
Nov 29, 2001 12:42 PM
