What are the benefit of type R cams in a non vtec teg?
Old Sep 14, 2003 | 08:16 PM
Komsomol's Avatar
Default What are the benefit of type R cams in a non vtec teg?
Also, what other recommended modifications go along with this swap?
Old Sep 14, 2003 | 08:18 PM
fivespeedintegra's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (8400RPMS)
uhm......they won't fit. vtec cams into non vtec engine = no go.
Old Sep 14, 2003 | 08:25 PM
Komsomol's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (fivespeedintegra)
I didn't think so...
I had some twit tell me he put type r cams in his otherwise stock rs.
So what high performance cam is recommended then for non vtec?
Old Sep 14, 2003 | 08:26 PM
teg92's Avatar
a vtec head!
Old Sep 14, 2003 | 08:29 PM
crower cams
Old Sep 14, 2003 | 09:07 PM
91tegrals's Avatar
jg makes good cams gude makes cams ef1 makes cams and crower makes cams so there are youre choices take youre pick..
Old Sep 14, 2003 | 09:56 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: (91tegrals)
Vtec cams won't fit a non-vtec head.
I believe due to the fact the rocker arms are on the other side.
I think....
Old Sep 14, 2003 | 10:01 PM
JaY-R's Avatar
it won't fit.. go with crower cams for a non vtec
Old Sep 14, 2003 | 10:57 PM
xkhalil333x's Avatar
tell him to beat it
Old Sep 15, 2003 | 05:12 AM
mr.beeks's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (teg92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">a vtec head!</TD></TR></TABLE>
go the LS/VTEC way
Old Sep 15, 2003 | 05:55 AM
IntEGNYC's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (francisco flores)
will upgrading the cams show a significant performance improvement?
Old Sep 15, 2003 | 06:23 AM
Audi A4's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (IntEGNYC)
cams arent going to do much, if you want power on aLS your gonna have to go boost.
Old Sep 15, 2003 | 10:14 AM
Hites
Guest
Posts: n/a
Default Re: What are the benefit of type R cams in a non vtec teg? (DRAG lll INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">cams arent going to do much, if you want power on aLS your gonna have to go boost.</TD></TR></TABLE>
couldnt agree more. low compression b18b + boost =
Old Sep 15, 2003 | 11:05 AM
ltho1998's Avatar
&lt;shakehead&gt; Vtec cams have 3 lobes on the intake and 3 lobes on the exhaust. 2 of them (the outer ones) are used for regular operation. The single center lobe is used during the vtec operation. Because of this you CANNOT use DOHC VTEC cams in a non-vtec motor. You can however, install a DOHC VTEC head (b-series) onto a non-vtec block and get DOHC VTEC-- like what i did. Its called a LS/VTEC. Use the search engine for that one if you want more info.
Observe: VTEC CAMS
Now non-vtec dohcs have only 2 lobes on the intake and 2 lobes on the exhaust.
Observe: Non-VTEC cams
(The above is cams from a Neon-- but you get the point)
Modified by ltho1998 at 8:16 PM 9/15/2003
Old Sep 15, 2003 | 11:40 AM
2lowintegra's Avatar
Default Re: What are the benefit of type R cams in a non vtec teg? (Hites)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">
couldnt agree more. low compression b18b + boost = </TD></TR></TABLE>
racinhatch
Apr 26, 2008 10:27 AM
1sikhatch
May 13, 2007 04:37 PM
ivicr
Jan 10, 2007 01:48 PM
