How are 98' up Accord rear seats held in place?
Old Sep 14, 2003 | 03:54 PM
captainkgun's Avatar
Default How are 98' up Accord rear seats held in place?
How can I take out the rear bottom seat?
Old Sep 14, 2003 | 04:59 PM
iam7head's Avatar
Default Re: How are 98' up Accord rear seats held in place? (captainkgun)
get a grip on the seat pad and put it out clean.. it's very easy.
it's only hold down by some plastic clips, make sure you dont loose or break those..they are like 25cents each
Old Sep 14, 2003 | 07:16 PM
Heat's Avatar
Default Re: How are 98' up Accord rear seats held in place? (iam7head)
Before you start pulling up on it, there's a bolt you have to remove first.
The bolt is located in the crevice of the seat, just left of the seatbelts between the middle seat and the driver's side back seat. Once that bolt is out pull the front of the seat, I believe, straight up to detach it from the clips referenced by the poster above. The clips are all on the front edge.
Removing the bolt was easy, it was very difficult to get back. In fact, I never did get it back in when I installed my trunk mounted CD changer almost 5 years ago.
Old Sep 15, 2003 | 01:46 PM
Default Re: How are 98' up Accord rear seats held in place? (Heat)
Thanks guys worked great!
EZ$$EF
Sep 17, 2008 12:17 PM
mxl36o
Mar 14, 2007 06:50 AM
D114
Sep 29, 2003 05:01 AM
USDMMARK
Jan 29, 2003 03:24 PM
Attoir
May 22, 2002 11:44 AM
