Apex Power FC
Old Aug 21, 2001 | 02:21 PM
JSpecwest's Avatar
New User
Default Apex Power FC
Has anyone had any experiences with this product or know where I can find information about it? Does it totally replace the ecu? Does it run with stock sensors? Thanks
Old Aug 21, 2001 | 02:26 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: Apex Power FC (JSpecwest)
http://www.bseries.net/images/jdmsir/c19.JPG http://www.bseries.net/images/jdmsir/c20.JPG http://www.bseries.net/images/jdmsir/c17.JPG
Good product Very user friendly and yes it replaces the entire ECU and it is made to run with the Stock sensors
Old Aug 21, 2001 | 02:35 PM
H23 Power's Avatar
Default Re: Apex Power FC (JDM_DOHC_SiR)
i would also like to know where i can read more about the Power FC
Old Aug 21, 2001 | 02:37 PM
Austin's Avatar
Damn...I didn't want to take mine apart, I spent way too long waiting for it to get here to me to risk screwing something up.
I have the PowerFC and it is fairly easy to program, that is if you have someone that knows what they are doing...any questions about it?
Austin
Old Aug 21, 2001 | 03:15 PM
RStoR's Avatar
Default Re: Apex Power FC (Austin)
Does it retain the OE knock sensor retard capability?
Old Aug 21, 2001 | 03:19 PM
New User
Default Re: Apex Power FC (RStoR)
.. Nope thats the only thing it doesn't retain...but from the options that it has you will be able to monitor the knock sensors output to the max limit before harmfull detonation happens.. hope this helped a little
Old Aug 21, 2001 | 03:21 PM
Austin's Avatar
I agree, as this is the only item that I'm not happy with, but I had already purchased a J&S Safeguard, so I'm not all that worried about knocking...the highest that mine gets up to is around 30, what about you?
Old Aug 21, 2001 | 03:25 PM
RStoR's Avatar
Austin~
Please elaborate on what "highest mine gets up to is around 30 means"?
Old Aug 21, 2001 | 03:27 PM
New User
Still waiting to get a wire harness so I can Put that bad boy in AAAAAarrrrrrr . Know of any body that has a 92~95 GS-R helms..that might want to scan the pin outs for me.??
Old Aug 21, 2001 | 04:07 PM
Austin's Avatar
Austin~
It's a measurement of how much knock your sensor is reading, because of the valve train/combustion you will have a small amount of readings from normal driving, but the stock computer does not retard until you reach a certain point...the PowerFC will flash your CEL rapidly if you are around 60(I think). I have the English directions for the RX-7, if you're interested I could e-mail them to you.
Austin
Old Aug 21, 2001 | 04:46 PM
RStoR's Avatar
Please do! Email to cbb13961@gsk.com. Thanks! More questions to come.
Old Aug 21, 2001 | 04:49 PM
Austin's Avatar
Have fun reading...
Austin
Old Aug 21, 2001 | 08:22 PM
Group 03's Avatar
New User
If i am interesting to get one 2 , which one should i buy.. i meant we can only get the POWER FC for GSR in North America,.. should i get that or buy the other car ..
As i remember the " TOP FUEL " civic is using the one for RX 7 so,,, i dont know help me out..,, The reason is i am going to turbo my car should i get a POWER FC which is made for turbo car ...thank u
Old Aug 21, 2001 | 08:28 PM
sgT's Avatar
sgT
Default Re: Apex Power FC (Onion Kid)
Unless the RX7 and honda have the same ecu plugs, then top fuel
uses the FC made for the CTR/ITR. You are interested in which
one fits the plugs and has the proper base program.
GSR FC will work fine.
deugenhiem
Jan 5, 2015 06:12 AM
Black R
Feb 16, 2004 03:44 PM
Ex-ITR5874
Mar 2, 2003 02:00 AM
JSpecwest
Aug 30, 2001 06:47 PM
