EG power windows upgrade problem. Please Help!
Old Sep 14, 2003 | 02:01 PM
IDriveHonda's Avatar
Default EG power windows upgrade problem. Please Help!
Yesterday I installed power windows and power locks off of an EX into a DX. I have done this before on my 99 hatch so I was pretty familiar with the process. After a very long day of working everything was installed and wired up. Everything works except for the drivers switch that controls the passenger window. The passenger window switch works and we did a continuity test on the driver switch for the passenger window and it appeared to work correctly. I thought that if it was in the wiring that the passenger window would not work at all but it does from that door. Do you guys think it is the switch? Let me know if you can. Once I figure this out I can probably create a DIY on it for help in the future. Thanks.
Old Sep 14, 2003 | 02:45 PM
.jacob's Avatar
Default Re: EG power windows upgrade problem. Please Help! (IDriveHonda)
Make sure it has a + lead. Each window requires a + lead.
Old Sep 14, 2003 | 02:47 PM
Default Re: EG power windows upgrade problem. Please Help! (Ninety2SiR)
It does, the passenger window works with the passenger switch, just not the drivers switch. I have the Helms manual and I followed it closely.
Old Sep 16, 2003 | 11:10 PM
Eks133p3r's Avatar
I how much should I expect to pay for all the parts to do a power windows/door locks for my EK.
Old Sep 17, 2003 | 03:48 AM
93CivicSI's Avatar
Write up on this......
Old Sep 17, 2003 | 04:53 AM
monicle's Avatar
It depends on how you did it. did you use factory wiring and wire it into the back of the fuse box and add the relay or did you just hook the motors up to power?
My install photos here http://repo.jackmoves.com/view...bun42
Old Sep 17, 2003 | 04:55 AM
93CivicSI's Avatar
Default Re: EG power windows upgrade problem. Please Help! (monicle)
Awesome - Thanks!!
Old Sep 17, 2003 | 11:32 AM
I got it. Thanks everybody. There were 2 blu/blk wires and I used the wrong one. It was late and I was tired.
Old Sep 17, 2003 | 03:15 PM
Default Re: EG power windows upgrade problem. Please Help! (EkToda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkToda &raquo;</TD></TR><TR><TD CLASS="quote">I how much should I expect to pay for all the parts to do a power windows/door locks for my EK.</TD></TR></TABLE>
I would expect to pay around $300 for all of the OEM parts to do this conversion, but you can negotiate your own prices in the classifieds.
Old Jul 26, 2004 | 08:51 PM
Cain Marko's Avatar
Rotary Lift Specialist
if i got all my stuff from a LS would it fit into my EG???
Old Jul 29, 2004 | 12:07 PM
Shelton's Avatar
Default Re: EG power windows upgrade problem. Please Help! (turtlecx92)
bump
Old May 12, 2005 | 09:52 AM
DJNauTicz's Avatar
so i guess i was the lucky one..got all the oem part's for 100$
dwardo55
Nov 20, 2012 07:45 AM
96blkteggy
Mar 19, 2011 03:19 PM
92widebodyeg
Nov 19, 2007 07:00 PM
robwilhelm
Sep 19, 2007 10:05 AM
mugenpower92ls
Mar 23, 2007 05:50 PM
