jdm type s
Old Aug 21, 2001 | 01:50 PM
carolinaACCORD's Avatar
Default jdm type s
what would be needed to put a 2000 jdm prelude type s motor into
my 1996 accord lx?
Old Aug 21, 2001 | 02:24 PM
SOHCArchangel's Avatar
Default Re: jdm type s (HONDApowerEXTREME)
well an h22 is an h22, so i beleive only the drivers side motor mount, ecu, and wire harness
Old Aug 21, 2001 | 09:44 PM
dshr's Avatar
New User
Its just like any other swap motor mounts etc............
Old Aug 24, 2001 | 08:10 AM
m0t0rhead's Avatar
It's a straight drop in, I'm almost positive that you don't even need to worry about the motor mounts. One suggestion would be to have a compression/leakdown test done and add a urethane bushing in the mounts. $5000 for the engine in good shape... you'd be better off with a 95 or 96 Type S. The only real difference is the pistons.. which add 20 HP
220 vs. 200 in a reg. JDM H22A
THe only thing that's a pain is the wiring.
Old Aug 24, 2001 | 10:41 AM
JinMTVT's Avatar
New User
Default Re: jdm type s (Escobar)
BZZZZZZZZ wrong..
the diff with the newere type S engine is the cams,springs,ecu,TB ob,intake manif,
port polish head, raised piston CR to 11.0:1 ,header and exhaust
and the intake box is diff too ..
so it's not just the pistons
Old Aug 24, 2001 | 06:22 PM
4doorH22's Avatar
Default Re: jdm type s (JinMTVT)
Just like any other H22 swap. It drops right in then you gotta take care of a bunch of little problems you never even thought would crop up.
Old Aug 28, 2001 | 08:10 AM
m0t0rhead's Avatar
Default Re: jdm type s (H22power)
like what ?
Old Aug 28, 2001 | 08:12 AM
m0t0rhead's Avatar
oh yeah.. the ECU is a P5P as opposed to a P13.
Type-S cams too
you sure about the port and polish ?
what's the size on the TB and intake manifold.. I thought they were the same?
Old Aug 28, 2001 | 08:21 AM
4doorH22's Avatar
Well since that's a JDM motor you shouldn't run into all the OBD I vs OBD II problems I did.
Fitment problems pop up (mostly with the motor accessories) for example I needed different axels and power steering pump and bracket.
Old Aug 28, 2001 | 08:35 AM
where is the best place to get all of the parts that i need for this, and also is there
anywhere else where i can get a helms manual besides the website?
.1type.
Sep 19, 2011 10:29 AM
2000h22a
May 20, 2008 01:02 PM
hybrid_KJ
Jul 1, 2003 12:48 AM
sirrach
May 13, 2003 10:15 AM
NW94RS
Oct 8, 2002 09:35 AM
