Header? What header?!?
yeah I need to get me one of those. nice. I see two parts in the pics. are there two parts to the upper section of the shield(s), like an inner shield and outer shield or is there just the one upper section ?
thanks.
J.
thanks.
J.
Pat~
I'll be over Thursday night when the Volvo Automechanic rolls into town!
We should be here. Valve adjustment + oil change on the local Gee Ess Are, and timing adjustment on Da Gun. I hear he is delivering some goodies to you!
am i missing something here? couldn't you just use the heat shield that already comes with your R...or do aftermarket headers protrude out more or something? just wondering why you'd have to buy a new set.
also, suppose you were pulled over by johnny law and he/she suspected you had an illegal header on your car. they'd probably be less inclined to make you take off that *blazin' hot* heat sheild to check it out no?
[Modified by kepani, 7:05 PM 8/21/2001]
The other is for another member of this board...
Must hide the header...
Just got the cat installed...
I will pick up the shield bolts tomorrow at the dealer...
Roll deep wif the "GeeTea" Volvo and meet you at the "Bush Lite" garage.
Much work to commence.
Will
-who likes to hide his modifications
sorry to anyone to whom these are lamea55 q's. i'm still new to this stuff...modifying and junk
yellow blur (or anyone else),
does that mean that this particular jdm heat shield (referring to above) or the usdm heat shield won't necessarily fit a mugen/spoon/etc. header?
this thread is a good one because it will definitely influence what kind of header to get. if i were to buy one...especially for one that wouldn't pass a visual inspection...i would want one that had a compatible heat shield. hence, when johnny law pulls you over...you won't be sweating basketballs hoping he doesn't ask you to pop your hood...
See how the header has the metal tabs in the top and sides of the header? That is where the shield bolts up. I pretty sure that no aftermarket header has those tabs.
Will
Heavier... much larger (size wise) than the factory one. The one above is one of 2 pieces. The second piece goes on the bottom of the header.
The factory USDM 2 piece shield is smaller and lighter... but does not cover the ammount of area that the JDM shields do.
Will
Will
willard, thanks for the illustration...
clears a lot of stuff up...i don't suppose people have made their own mounts on a non-honda header to allow a heat shield hook up? that would sell pretty well i'd think...just think...you don't have to drive around with a buck naked header...
Why are those heat shields on your bed? This whole "love of hondas" is getting out of hand...hehe
Heat shield will be installed tonite. I'll take a before and after pic for interested parties.
Cool! Just come on around back. I expect Will between six and seven. On the agenda:
1) Valve adjustment on Meech's GSR
2) Oil change on said GSR
3) Steering wheel swap in Da Gun
4) Heat shield humping by Chris
5) Cleaning of heat shield, followed by installation into Number Nine
6) Photo ops, time and light permitting
7) Beir
7) Beir
RStoR........you arn't the only one that wants a look at that header. Although, I've heard you do more then look.haha
Do you guys get the back heat shield? I see the front!
That is my next mod to my car.......Where did you all perchase your Header and Heat Shields? What Cat are you running? When I come home in a couple of months, I'd love to see it.
Drinker
