Did my compression test...
Old Sep 14, 2003 | 10:29 AM
91TegLS's Avatar
Default Did my compression test...
Well the numbers are in.
Cylinder 1: 110
Cylinder 2: 90
Cylinder 3: 105
Cylinder 4: 110
Not exactly sure if I did it right.. but if I didn't, I did do it consistantly wrong.
Whoever thinks my engine's about to blow, say "I"
Old Sep 14, 2003 | 11:13 AM
J337_UNIT's Avatar
Default Re: Did my compression test... (91TegLS)
wow those are bad numbers bro...minimum psi allowable is 135 i believe with a +-10 psi variation...remember stock from the factory psi for the b18b is 200psi....are you sure you had the throttle body wide open when you cranked th emotor/????make sure you press that gas pedal down when you crank motor to open it the T/B up...if you did this correctly...then those numbers you provided are bad.
EDIT: with 49,000 miles on my b18b motor i pulled 195 straight across the board.
Old Sep 14, 2003 | 11:53 AM
91TegLS's Avatar
Default Re: Did my compression test... (J337_UNIT)
maybe I did do it wrong.. refresh my memory on the procedure.
Edit: BTW it's a B18A1.. but pretty much the same thing
Old Sep 14, 2003 | 12:02 PM
91tegrals's Avatar
damn thoughs are some bad #s..but hey now you have a excuse to rebuild..
Old Sep 14, 2003 | 12:07 PM
J337_UNIT's Avatar
warm up engine to normal engine temp...shut it down...remove the 15a fuse under the under titled ECU or F/I...remove all sprak plugs...put tester in spark plug hole screw it in hand tight...go back in you car and press clutch and gas pedal alll the way down...crank motor for at least 5 compression cycles...youll hear it like wee - wee- wee -wee - wee...its way slower then when you go to start your car..then get out of your car and read the gauge...repeat this process with each cylender.
Old Sep 14, 2003 | 12:44 PM
Jet Black's Avatar
Must have had the TB closed...those are horrid numbers, your car would be running like ***
Old Sep 14, 2003 | 01:11 PM
Audi A4's Avatar
Default Re: Did my compression test... (Jet Black)
no misfiring codes or anything? does it feel sluggish?
Old Sep 14, 2003 | 04:21 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Did my compression test... (DRAG lll INTEGRA)
Aside fromt the fact that more than likely you did it wrong, you may went to do a cylinder leak down test.
#2 is way low.... You should do a leak down, to find out what is wrong with your second cylinder.
Generally +/- 20psi variation between max and min. is the max variation you should have... You have a 20psi variation, you really need to get that checked out.
Old Sep 14, 2003 | 07:48 PM
91TegLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">warm up engine to normal engine temp...shut it down...remove the 15a fuse under the under titled ECU or F/I...remove all sprak plugs...put tester in spark plug hole screw it in hand tight...go back in you car and press clutch and gas pedal alll the way down... crank motor for at least 5 compression cycles...youll hear it like wee - wee- wee -wee - wee...its way slower then when you go to start your car..then get out of your car and read the gauge...repeat this process with each cylender.</TD></TR></TABLE>
hmm.. maybe it was the fact that I only cranked it once
Old Sep 14, 2003 | 08:21 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">
hmm.. maybe it was the fact that I only cranked it once </TD></TR></TABLE>
LOL well theres your problem right thurrr...
your really supposed to crank the motor till the needle stops climbing so it may take 4 cranks it may take 5 or it may take more...just make sure your motor is warmed up when you do it also..cuz when motor is cold , the piston rings and everything arent fully expanded. i did a cold test on my car and the results were 10 psi lower on all the cylenders as opposed to when i did a warm compression check.
Old Sep 15, 2003 | 11:00 AM
projectTeG's Avatar
hey can some one tell if mine are good?
#1 180
#2 150
#3 170
#4 160
iuno...but my car burns oil at start up and sometimes while sitting at a stop...PLZ help!!!!
Old Sep 15, 2003 | 11:02 AM
J337_UNIT's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">hey can some one tell if mine are good?
#1 180
#2 150
#3 170
#4 160
iuno...but my car burns oil at start up and sometimes while sitting at a stop...PLZ help!!!!</TD></TR></TABLE>
your numbers are not consistent at all...something could be wrong with your motor.
Old Sep 15, 2003 | 11:49 AM
91tegrals's Avatar
yeah it looks like you may have some busted rings with that much of a gap in compression...
Old Sep 15, 2003 | 03:43 PM
es four's Avatar
#1 180
#2 150
#3 170
#4 160
No, not at all. 180-150= 30psi variance. That is very bad.
.....but you know that because you read the rest of the thread, right?
Old Sep 15, 2003 | 04:57 PM
mickey513's Avatar
Default Re: (integra707)
Does the engine have to be warmed up before the compression test?
Old Sep 15, 2003 | 05:03 PM
J337_UNIT's Avatar
Default Re: (mickey513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickey513 &raquo;</TD></TR><TR><TD CLASS="quote">Does the engine have to be warmed up before the compression test?</TD></TR></TABLE>
yes
Old Sep 17, 2003 | 01:51 PM
91TegLS's Avatar
Default Re: (J337_UNIT)
Heh.. did it the right way now.. very impressive.
Cylinder 1: 200
Cylinder 2: 195
Cylinder 3: 193
Cylinder 4: 210!
I'm happy and sad at the same time, wanted a new engine.
Old Sep 17, 2003 | 03:57 PM
es four's Avatar
Default Re: (91TegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">Heh.. did it the right way now.. very impressive.
Cylinder 1: 200
Cylinder 2: 195
Cylinder 3: 193
Cylinder 4: 210!
I'm happy and sad at the same time, wanted a new engine.</TD></TR></TABLE>
Those numbers still aern't good.
210-193= 17psi variance. Thats not good.
Do a leakdown test.
sjracer
26
Aug 1, 2013 09:42 PM
delsolo95
Apr 3, 2013 08:49 AM
2000civic-Si
12
Aug 29, 2005 11:47 AM
disboilikehoy
May 23, 2004 05:41 PM
Chubz
Jun 27, 2002 02:00 PM
