Have you ever stripped your oil pan drain threads while chaging your oil
Old Aug 21, 2001 | 01:07 PM
EVOCELICA's Avatar
New User
Default Have you ever stripped your oil pan drain threads while chaging your oil
I just got a SiR change over and I went to go and chage the oil and the drain plug was stripped I put the bolt back in and it would just keep turning and turning it wouldn't get any tighter. So I went to Acura and one of the techs told me about a cool tip in how to fix it. He told me that the integra drain plug bolt doesn't thread all the way in and he said to purchase a Legend drain plug which is longer and would catch the last 3 threads in the pan. So I get home and without a problem the Legend bolt fits right in and tightens all the way down problem was fixed for the mere cost of a bolt. Just thought I would share my new tip for the day with everyone else.
Old Aug 21, 2001 | 01:32 PM
junglistgsr's Avatar
Default Re: Have you ever stripped your oil pan drain threads while chaging your oil (EVOCELICA)
hmm, how much was the bolt and whats the part #?
Old Aug 21, 2001 | 05:34 PM
owen_the_soyboy's Avatar
wow that is a great bit of info!
thanks for sharing
Old Aug 21, 2001 | 08:03 PM
EVOCELICA's Avatar
New User
Default Re: Have you ever stripped your oil pan drain threads while chaging your oil (junglistgsr)
The part number is 90009-PY3-000 the price was like 4 dollars
Old Aug 22, 2001 | 05:19 AM
troy00gs's Avatar
New User
Did your stock bolt have the replaceable washer on it? If it did you can also add another washer to it and it should work.
Louka Grenon
Acura TSX
Jul 31, 2019 01:53 PM
supadupafast
Aug 11, 2013 09:57 AM
ombl4
May 10, 2007 01:42 PM
MechEng
Oct 21, 2005 12:14 PM
Nos4R2
Jul 1, 2003 06:09 AM
