VAFC questions
Old Sep 14, 2003 | 08:21 AM
youngvedder's Avatar
Default VAFC questions
Hey Guys,
had a couple of questions. Found a guy in my area that is selling a vafc. what should I be looking for when purchasing?
1. are all vafc's the same? (will it fit my 2001 GSR)
Looking at my set up, is a Apexi VAFC the right way to go?
cheers,
YV
Old Sep 14, 2003 | 09:11 AM
Dirty GS-R's Avatar
New User
Default Re: VAFC questions (youngvedder)
They are all the same, so don't worry about that. It will work on your car. It will definitely help with your setup. I actually just installed one on my '01 GSR, so if you need some help let me know. I'm from Brampton, so we're not too far from one another.
Old Sep 14, 2003 | 10:40 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: VAFC questions (Dirty GS-R)
there's a version 2 that costs more and has a few more features but has a different interface.
the version 1 would probably be cheaper now because of that, and it would suffice more than enough for your setup.
Old Sep 14, 2003 | 12:16 PM
patdemps's Avatar
Default Re: VAFC questions (dLo GSR)
yes, a vafc will be beneficial to your setup. have you tuned your car yet? with those cams/cam gears you would see a ton of extra power at the dyno if you tuned the car.
Old Sep 14, 2003 | 12:41 PM
Default Re: VAFC questions (patdemps)
thanks guys,
I went and picked it up, so I will hopefully get it going this week. Any good links on the install process?
cheers,
YV
Old Sep 14, 2003 | 12:52 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngvedder &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys,
cheers,
YV</TD></TR></TABLE>
You can download the instruction manual and wiring diagram from A'PEXi.com.
Old Sep 14, 2003 | 04:47 PM
Blk95GSR's Avatar
Default Re: VAFC questions (Padawan)
you only ran a 15.2 and you have ITR cams?
Old Sep 14, 2003 | 05:04 PM
Default Re: VAFC questions (Blk95GSR)
yeap.....parially due to poor launcher and poor traction....
car is not tuned....hopefully that will improve things..
YV
Old Sep 15, 2003 | 04:21 AM
another question....
can I use the VAFC on either my obd I or obd II?
YV
Old Sep 15, 2003 | 02:02 PM
hey.
just trying the install now.....did you use diagram h7-a for the install?
what ECU are you running it off?
thank,
YV
Old Sep 15, 2003 | 02:08 PM
B2FiNiTY's Avatar
VAFC will run on either obdI or II. Use the proper diagram from http://www.apexi-usa.com
Old Sep 16, 2003 | 07:50 AM
Anyone have any idea of what the VTM wire is for?
Install went well, just need to recheck the throttle wire (not getting accurate readings). other than that, easy install!
YV
Vtecme92
Jun 4, 2006 12:44 PM
OEMRedEG
Feb 24, 2004 05:10 PM
Caveman74
Nov 27, 2003 01:41 PM
OutLaw MR
Aug 4, 2003 10:12 AM
Type_EK_R
Apr 5, 2003 10:28 PM
