VAFC V/T unmt setting (quick question)
This was the only setting i never changed when installing the hack....Can you guys please tell me what you have this setting set to?
greddy kit with intercooler at 9psi with hack on a d16z6.
The manuel says for the description of V/T unmt "When the desired engine RPM adjustment point is between setting points, adjust the two points before and after the desired points to compensate"
