Crankshaft Pulley Fell off 6th gen accord *Help
Old Sep 14, 2003 | 06:29 AM
immalooser's Avatar
Default Crankshaft Pulley Fell off 6th gen accord *Help
Well on my friend's 4 cyl 6th Gen accord, his crankshaft pulley feel off taking the alternator and PS belts. Upon closer inspection, we discovered that the crankshaft bolt broke into two pieces. We had the car towed to his home and started working on it. We first drilled into the broken bolt and then used a reverse drill bit and luckly we got the broken bolt out!.
Here's the problem. On the crankshaft pulley, there is this one "pin" I believe it's called an alignment pin. Currently this pin cannot the slot so we can't put on the pullley. It seems to me that this pin was holding about three plates in place. We've gotten two of them aligned, however, we can't find the thrid plate so the entire pin will fit in. How can we get all three in place? Is it just going to be a guessing game?
Old Sep 14, 2003 | 07:38 AM
bill-71SS's Avatar
Default Re: Crankshaft Pulley Fell off 6th gen accord *Help (immalooser)
if the keyway came out, it is very possible your crank pulley for your timing belt moved also,it is lined up and held in by that keyway. you may want to pull off the timing cover and make sure.
Old Sep 14, 2003 | 08:10 AM
immalooser's Avatar
Default Re: Crankshaft Pulley Fell off 6th gen accord *Help (bill-71SS)
Yeah that's pretty much what has happened.
I'm trying to figure out how to realign it back into place.
Anybody know how to?
Old Sep 14, 2003 | 10:58 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immalooser &raquo;</TD></TR><TR><TD CLASS="quote">Yeah that's pretty much what has happened.
Anybody know how to?</TD></TR></TABLE>
You'll probably have to pull off the lower cover.
Old Sep 14, 2003 | 09:18 PM
kleankord's Avatar
any OTHER way?
kytarheel71
Sep 7, 2008 11:56 AM
landscapenate10
Jul 12, 2008 07:07 PM
Sampsonite987
Nov 13, 2007 06:19 PM
Leo330
Aug 29, 2007 07:35 PM
Joe 91 Accord
Jul 26, 2003 12:00 AM
