Suspension 95 / 96 civic front shocks ???
I know that the rear shocks for a 92-95 eg hatch and a 96-00 ek hatch don't fit each other. What I want to know is if the front shocks will fit each other ?????
Yes they will work but if you use 96-00 fronts on a 92-95 then you don't have a place to bolt the brake lines on. You'll need to ziptie the brake lines to the strut or something. That's what I did a few years ago when I used some 96+ struts, never had any problems. If you were to do the reverse setup, (EG struts on EK) then you obviously have mounts where you don't need them so it's not a big deal, hack them off if you want.
bmoua
15
Jul 5, 2007 03:49 PM
boostn5Ghaba
Jul 12, 2004 07:12 PM
