ITR engine swap question.
Old Aug 21, 2001 | 12:05 PM
Mr. Potato Head's Avatar
Default ITR engine swap question.
Need info on swap consisting of 99Si head ITR BLOCK, using p73 comp. from 97/98 ITR. The computer is OBDII but there is no cat to bolt to my header that would house the second o2. Then theres the issue of a cat back exhaust. Nobody makes exhaust for this set up and a muffler shop cant bend pipe for **** so any suggestions are appreciated.
Old Aug 21, 2001 | 12:15 PM
Black R's Avatar
25 Year Member
Default Re: ITR engine swap question. (Kermit)
get a test pipe with o2 bung. or get ecu rechipped (you'll need to anyway to raise rev limiter and then remove 2nd o2 programs).
You might be better off with a 94-95 gsr ecu rechipped with the a/f maps you need and higher rev limiter. no 2nd o2 sensor, and retains the factory knock sensors.
As far as exhaust, any good shop can do one up for you with mandrel bends...
What chassis is this going into?
Old Aug 21, 2001 | 12:34 PM
Default Re: ITR engine swap question. (Black R)
96EK chassis .
Rikaro
Sep 6, 2009 03:22 AM
ITR981002
Aug 26, 2003 07:14 PM
sk!tz0
Jun 17, 2003 05:15 PM
fredtoast
May 9, 2003 12:30 PM
TurboBumblBee
Jan 23, 2002 04:22 PM
