Did a 5spd swap, bled clutch, now clutch seems to not disengage.
Old Sep 13, 2003 | 03:13 PM
AKUFC's Avatar
Default Did a 5spd swap, bled clutch, now clutch seems to not disengage.
Car : 5th gen Accord
Motor : f23
tranny : h23
Did a 5spd swap and motor swap on the car. Everything is hooked up correctly, but when the car is on I can't get into gear. I've bled the clutch and there is no more air in the lines. If you start the car with it in first the whole car just lurches forward liek the clutch isn't disengaging at all. When the car is on it wont even go into first. When you put it into 2nd (with the clutch still in) the car will roll forward even though the clutch is in...can't even get into any of the other gears. We aligned the clutch w/ the tool so that's not the problem..if it helps any using a cm stage I w/ a cm flywheel. We checked the lines and nothing is kinked.
What else do I need to do? Kinda stuck here. Thanks
Old Sep 13, 2003 | 04:02 PM
AKUFC's Avatar
Default Re: Did a 5spd swap, bled clutch, now clutch seems to not disengage. (AKUFC)
follow up -
I adjusted the clutch pedal. The bolt is almost all the way up and it really didn't make a difference. The fork on the slave cylinder is moving it about 1/2" in and out. Someone told me it's supposed to move about 1" and more back and forth. That would seem like a problem to me..
FeelTheBass
21
Apr 7, 2022 11:41 PM
stc876
Transmission & Drivetrain
13
Dec 14, 2015 02:55 PM
phokingthai
Jul 4, 2014 01:53 PM
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
VtecVillan
Oct 28, 2007 12:56 PM
