Are the MAP sensors the same?
Old Sep 13, 2003 | 02:21 PM
DropSquadCivic's Avatar
Default Are the MAP sensors the same?
I just got a map sensor from a 91 teg, it should work for my h22 right? they all do pretty much the same thing. THey look different as hell.
Old Sep 13, 2003 | 02:26 PM
Kataku2K3's Avatar
Default Re: Are the MAP sensors the same? (DropSquadCivic)
Honda MAP's all use the same plug in general but there are two different kinds... The firewall mounted type which runs a vacuum line to the throttle body and the TB mounted type, which doesn't require the line... In your case, so long as you have a non TB mounted MAP you could use either style... Peace
preludeNApower
Aug 15, 2012 04:14 AM
chris3385
Jan 3, 2009 04:49 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
coot_er
May 11, 2004 08:32 PM
B18C-RnVA
Aug 18, 2002 03:01 PM
