B20 VTEC leaking oil
Old Sep 13, 2003 | 11:32 AM
erbinone's Avatar
Default B20 VTEC leaking oil
I just got my B20 VTEC back this week and I'm leaking oil out of the corner where the engine stamp is. Is this normal? Why is this? How can i fix this?? Any info will help! This pic was taken this morning after I just degreased the motor and moved it back in my driveway... didn't even drive it yet!
Old Sep 13, 2003 | 12:10 PM
MidoriEK4's Avatar
Default Re: B20 VTEC leaking oil (erbinone)
ah yes the joy of b20vtecs. i had the same problem. the only thing i could think of is the head gasket. did you use copper spray on both sides of the gasket?
Old Sep 13, 2003 | 12:26 PM
erbinone's Avatar
Default Re: B20 VTEC leaking oil (FI CRX Si)
it was a new gasket... i don't think so.
Old Sep 13, 2003 | 12:31 PM
MidoriEK4's Avatar
hmmmm. if anything i would try taking it out and try using the copper spray. but i have also heard that there is a 50% chance of getting the gasket to seal correctly. also when you re-did your dowl pins are they sitting down deep enough?
Old Sep 13, 2003 | 12:36 PM
erbinone's Avatar
yeah...tthey were in there deep... I guess we will pull the head, spray the gasket and check the dowel pins?!
Old Sep 13, 2003 | 12:40 PM
MidoriEK4's Avatar
when you pull it off it will tell you alot. just my 2 cents.
Old Sep 13, 2003 | 12:52 PM
erbinone's Avatar
great.... thanks for the quick responses.... what are you running?
Old Sep 13, 2003 | 12:55 PM
MidoriEK4's Avatar
well i did run a b20vtec in my crx. but that was a disaster with the builder.
DaN
Old Sep 13, 2003 | 12:57 PM
erbinone's Avatar
disaster? why??
Old Sep 13, 2003 | 01:11 PM
MidoriEK4's Avatar
builders fault i dont wanna mention any names, but my new project will be a EK9 with a fully built all motor h22. if you need any parts off my b20vtec let me know.
DaN
Old Sep 13, 2003 | 01:17 PM
erbinone's Avatar
Great!. Thanks,.... yeah, I'm ready to sell my ef. I really want an eg coupe w/ another B20 VTEC. I just hope I can get the dam head to seal!
Old Sep 13, 2003 | 01:29 PM
9x1000rpm's Avatar
which head gasket did u use?
Old Sep 13, 2003 | 01:39 PM
Chris Benoit's Avatar
does anyone know if they 50% chance of getting it to seal properly is correct?
Old Sep 13, 2003 | 01:41 PM
MidoriEK4's Avatar
Default Re: (93cxhybrid)
well its not 50 but i know the chances of getting it sealed is like a matter a luck. do a search and see what other people have said.
DaM
Old Sep 13, 2003 | 01:42 PM
six sigma racing's Avatar
before pulling the head off.. check the Vtec solinoid gasket.. it might be rips and the oil is just leaking donw making it look like its coming from the head gasket... just double check everything before pulling it all apart.... save ya some time...[
Old Sep 13, 2003 | 01:44 PM
snowseeker's Avatar
I have seen this before where it looks like it is comming from the head gasket. But if you look closely it sometimes is comming from the half moon in the valve cover gasket. When you install the valve cover gasket you have to put a thin layer of RVT in the half moons and the cam cap corners.
Just something to look at.
Old Sep 13, 2003 | 02:07 PM
rexnst9's Avatar
Is this the only spot around the head that you are seeing a leak? Having a leak in this corner could be a problem with the plug used to block the oil passage in the head. I have seen them leaking by the plug on a few of these head swaps. Maybe it's not in your case but thought I would put that out there. Good luck with it.
Old Sep 13, 2003 | 02:09 PM
smokey2.0's Avatar
Default Re: (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">I have seen this before where it looks like it is comming from the head gasket. But if you look closely it sometimes is comming from the half moon in the valve cover gasket. When you install the valve cover gasket you have to put a thin layer of RVT in the half moons and the cam cap corners.
Just something to look at. </TD></TR></TABLE>
check all the provable leak sources, once you rule all them out re-torque the head. if after retorqueing the head, the leaking does not seize you'll need to remove the head. once the head is off, the first thing to look for is at the oil passage block off. make sure that it was sealed with a good thread sealer, and also make sure that you use a head gasket for the bottom end you're running ex, ls bottom end needs ls head gasket, b20 bottom end needs b20 head gasket. do not use an ls head gasket on a b20 block! good luck
Old Sep 13, 2003 | 02:52 PM
erbinone's Avatar
Default Re: (smokey2.0)
new b20 head gasket, new vtec solinoid gasket, new cam shaft gasket... will double check all before pulling off head. Thanks all!
Old Sep 14, 2003 | 11:09 AM
erbinone's Avatar
Default Re: (erbinone)
I started the car and looked to see where it was leaking from. It looks like it's coming from the cam shaft seal. Are those STR billet ones any good or how can I get this one to seal?
Old Sep 14, 2003 | 11:26 AM
smokey2.0's Avatar
i would just buy a str one, i have used it before and it's pretty good. it should cost you no more than 30 bucks, or you can just clean the old one and apply a good coat of hondabond!
Old Sep 14, 2003 | 12:02 PM
turbociv's Avatar
I had thought my head gasket was leaking also but it turned out to be the o-ring on the distributer shaft. just another thing to check out.
Old Sep 14, 2003 | 12:22 PM
erbinone's Avatar
Default Re: (turbociv)
great.... lots of good info, I know for a fact that the cam shaft seal is leaking and I will check for the dizzy "O" ring too. Thanks, where's the cheapest place to buy STR stuff??
Old Sep 14, 2003 | 12:27 PM
turbociv's Avatar
http://www.azracemachine.com has good billet cam seals for a good price.
Old Sep 14, 2003 | 12:38 PM
erbinone's Avatar
Great! Thanks for all the help. Buying it right now!
