Changed pistons what hp gains should I expect and what compression
b18a bottom end , b16a head
I had pr3 pistons now I ordered some PCT ctr pistons, I think the compression will be around 12 to 1, the head was resurfaced.
I wonder what my whp will be, head is ported polished, 3 angle, titanium retainers, dual valve spring
cat cams race cams(race ones) same specs as skunk2 stage 2, skunk2 manifold, cam gears, hondata, header , intake , exhaust , gutted car, FPR, pw0 ecu
I am thinking 190 at the wheels but well see....hoping for 200
sounds similar to my set up.
All Motor
Ls/Vtec
Si(R) P30 pistons
Ls rods/Arp rpd bolts
Stock Type R head and Intake Manifold (unported)
65mm Throttle Bodie
Crower cams and Valvetrain
P08 ecu chiped
Field Vtec controler
c12 race gas
jdm dc 4-1 header
Modified by shant at 6:49 PM 9/13/2003
All Motor
Ls/Vtec
Si(R) P30 pistons
65mm Throttle Bodie
P08 ecu chiped
c12 race gas
jdm dc 4-1 header
Not sure how accurate it is, but I always use it when im lookin for a ballpark figure of oem compression.
Edit; forgot the webpage. http://www.bojangs.com/calculator/
