Camber kit with OEM 'R springs on a GSR?
Old Sep 13, 2003 | 08:56 AM
ragejed's Avatar
Default Camber kit with OEM 'R springs on a GSR?
Got my alignment on my GSR today. It has full ES bushings, and OEM Type R springs. My camber is .9 on the left, and 1.8 on the right!!!
Old Sep 13, 2003 | 03:33 PM
slimbo's Avatar
Default Re: Camber kit with OEM 'R springs on a GSR? (ragejed)
is that front or rear?
taken any hits before??
Old Sep 13, 2003 | 05:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That definitely sounds like a problem with one of the suspension pieces, possibly a bent arm or something. You better check out the suspension real closely on that side w/ -1.8. With H&R Sport springs I'm sitting at -2.3 on both left and right in front on my car.
Old Sep 13, 2003 | 06:42 PM
ragejed's Avatar
Default Re: Camber kit with OEM 'R springs on a GSR? (PatrickGSR94)
how about get a camber kit and call it a day?
Old Sep 13, 2003 | 06:46 PM
5spdIntegra's Avatar
Arent those springs only like a 1in drop?
Old Sep 13, 2003 | 06:54 PM
Community Builder
Default Re: Camber kit with OEM 'R springs on a GSR? (5spdIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">how about get a camber kit and call it a day?</TD></TR></TABLE>
That would only be a band-aid fix. He needs to find the real problem of having the camber so far off on one side vs. the other. A camber kit definitely should not be needed w/ ITR springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5spdIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Arent those springs only like a 1in drop? </TD></TR></TABLE>
Not even 1", which is why it's not right for one side to have -1.8 deg. while the other side has -0.9 (which is right about the correct spec for ITR's).
Old Sep 13, 2003 | 09:29 PM
neo1z's Avatar
Id really have your suspension checked out...The last thing you should need is a camber kit with the oem ITR springs.
Old Sep 13, 2003 | 09:51 PM
Bill Hook's Avatar
Default Re: Camber kit with OEM 'R springs on a GSR? (neo1z)
I've got -1.1 on both sides in front.
Old Sep 14, 2003 | 12:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">Id really have your suspension checked out...The last thing you should need is a camber kit with the oem ITR springs.</TD></TR></TABLE>
Thats what I was thinking.
Old Sep 14, 2003 | 06:41 AM
ragejed's Avatar
How do I check it out though? Like how do I know if the metal pieces are straight and what not?
Old Sep 14, 2003 | 12:38 PM
Community Builder
Well if something hit it hard enough to bend it, I would be you would be able to tell by looking at it. Compare it to the opposite side if you have to.
Old Sep 14, 2003 | 12:43 PM
fivespeedintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">How do I check it out though? Like how do I know if the metal pieces are straight and what not?</TD></TR></TABLE>
jack the car up and take a look at the pieces down there. definately sounds like something is out of whack
JDM_nUt
Feb 17, 2010 10:33 PM
allmotorEG-SI
Jun 12, 2003 12:00 PM
Understeer
Jul 28, 2002 02:44 PM
uNF$@#!
May 5, 2002 12:48 PM
