Sway bar/exhaust rattle
Old Aug 21, 2001 | 09:24 AM
ken's Avatar
ken
Default Sway bar/exhaust rattle
Yesterday I installed a ITR sway bar on my GSR and it now the gap between the stock GSR exhaust and the thicker ITR bar is too small, so when driving, part of the exhaust pipe hits against the sway bar making a very annoying and loud rattle, as well as slowly making a hole in the exhaust piping. I tried putting a rubber clamp around the exhaust pipe, but the rubber quickly melted.
Anyone know od anything I can put between them that won't burn up, melt, or fall off? It only needs to be a temporary fix, since I'll be getting a custom exhaust made, and they can work around it.
Old Aug 21, 2001 | 10:25 AM
gsrpowered95's Avatar
New User
Default Re: Sway bar/exhaust rattle (SeaDawg)
I was curious how did you do the vtec light on your dash haha that is pretty cool I would like to do one of those
Old Aug 21, 2001 | 10:40 AM
SteelCityKid's Avatar
New User
I have the same problem. My stock GS-R sway bar comes in contact with my DC (I had to have the DC lowered for my rear valance on my bumper for muffler outlet to clear.)
I have rubber wrapped on the sway where it hits. Stops the "thunk" temporarly. It lasts longer than a rubber clamp on the exhaust itself.
I'm looking for a better solution myself.
Old Aug 21, 2001 | 11:07 AM
BSQ's Avatar
BSQ
Make sure that you do not have the swaybar installed upside down.
Here is a picture of how the swaybar should look when installed.
Old Aug 21, 2001 | 11:50 AM
ken's Avatar
ken
Default Re: Sway bar/exhaust rattle (BSQ)
I doubt I'd be able to get completely through the install with it upside down... if it was upside down, either the endlinks would fit but the main bushings wouldn't, or the other way around. Everything is in there as it should.
The rattle happens right where the sway bar curls up just before the endlink.
Old Aug 21, 2001 | 12:00 PM
BSQ's Avatar
BSQ
Trust me...the Type-R rear swaybar can be installed upside down. I have had several people contact me with the exact problem (ie. swaybar hitting the exhaust pipe) and each time it was caused by the swaybar being installed upside down.
Check and make sure that the swaybar "bends" down and not up.
Old Aug 21, 2001 | 12:23 PM
gsr camel's Avatar
I doubt he put it in the wrong way when I put my 5zigen axelback exhaust on it was hitting the sway bar and it really was pissing me off. I finally got a hks exhaust and it solved the problem but my sway bar is factory and unless honda mounted it wrong from the factory then thats not why it is tapping.
I fixed mine by bending the hangers. It worked but caused problems when trying to remove the 5zigen pipe.
Old Aug 21, 2001 | 12:26 PM
ken's Avatar
ken
Holy ****! You can get it in upside down! Damn, I feel like a complete idiot. I remember reading "check the way it bends" on the instructions, then looking at the picture. I couldn't really see though since the print out was kinda crappy, so I just held it up, it lined up, so I put it in. I'll have to fix that after work.
Old Aug 21, 2001 | 12:31 PM
BSQ's Avatar
BSQ
Default Re: Sway bar/exhaust rattle (gsr camel)
The Type-R rear swaybar and the stock swaybar have the exact same shape, so if the stock swaybar wasn't hitting the exhaust the Type-R swaybar should not be hitting it either. He mentioned that the swaybar is hitting his stock exhaust, therefore it shouldn't be the exhaust.
Old Aug 21, 2001 | 12:49 PM
BSQ's Avatar
BSQ
Don't feel bad...it's an easy mistake to make. At least it is easy enough to correct.
justinwinn
Nov 25, 2010 04:31 PM
Maireeka
Suspension & Brakes
Nov 12, 2007 03:17 PM
EG_93Civic
Jul 25, 2005 03:30 PM
JFG Kevin
Mar 6, 2004 04:54 PM
porch
Oct 30, 2001 06:16 PM
