Adjusting Valves... Raspy noises...???
Old Sep 13, 2003 | 04:31 AM
redlinex's Avatar
Default Adjusting Valves... Raspy noises...???
yea... today i pulled up next to my friends house and he was commenting on how badly my car sounds and that i needed to get my valves adjusted... according to him its a "pinging sound, kinda like a diesal car" and it does kinda have a raspy nasty idle sound... that i dont hear while im driving...
if this is so... where do you guys get ur valves adjusted? honda / acura dealerships ONLY! or any honda/acura motor shop? and how much does it run ya about...? thanks!!!
Old Sep 13, 2003 | 04:57 AM
fivespeedintegra's Avatar
Default Re: Adjusting Valves... Raspy noises...??? (redlinex)
almost all the guys on here adjust the valves themselves.
Old Sep 13, 2003 | 10:52 AM
Blk95GSR's Avatar
Default Re: Adjusting Valves... Raspy noises...??? (fivespeedintegra)
you need a feeler gauge set and some wrenches/screw drivers. its pretty easy to DIY. you MIGHT have to change your valve cover gasket though, they are rubber and can break upon removal, but if you keep it intact it will still work. The gasket kits for the valve cover are like $40.
Old Sep 16, 2003 | 01:26 PM
GSRacer1's Avatar
Default Re: Adjusting Valves... Raspy noises...??? (Blk95GSR)
Eery time I open my valve cover I just put some silicone on outside with the gasket for a better seal.
you dont need to buy a new seal every time just make sure the seal is good
Old Sep 16, 2003 | 02:01 PM
Blk95GSR's Avatar
Default Re: Adjusting Valves... Raspy noises...??? (GSRacer1)
rubber deteriorates over time though.
Old Sep 16, 2003 | 02:55 PM
Vtecfool's Avatar
yea, i called acura last week and they're charging $696 for the timing belt change!
Old Sep 16, 2003 | 03:02 PM
Default Re: Adjusting Valves... Raspy noises...??? (Vtecfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool &raquo;</TD></TR><TR><TD CLASS="quote">yea, i called acura last week and they're charging $696 for the timing belt change! </TD></TR></TABLE>
ouch....time to shop around!!
Old Sep 16, 2003 | 03:26 PM
patdemps's Avatar
if you have never done a valve adjustment before then there is in detail instructions on c-speedracing.com.
you should definately get the valve adjustment though. makes a world of a difference with your car. its definately expensive with the dealer, but your also getting top of the line work. if you have a friend that does work on cars then ask him to help you out and teach you.
Old Sep 16, 2003 | 05:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It's pretty difficult w/ a bent wrench and screwdriver. The correct tool makes it much easier. I have the one from Harbor Freight, back when they used to sell them. My friend and I adjusted the valves on both our cars Saturday. He worked the feeler guage while I worked the adjusting tool, only took about 45 minutes on each car.
Killspeed93
Jan 26, 2011 05:35 PM
Slomo_civic
Sep 19, 2005 08:18 PM
alias 33
Apr 16, 2004 11:57 AM
thehondaguru
Jun 15, 2003 10:28 AM
2000GSR
Jul 15, 2002 05:23 AM
