11.0.1 cr JE pistons for h23
Old Sep 12, 2003 | 08:08 PM
thehondaguru's Avatar
Default 11.0.1 cr JE pistons for h23
Would this be safe with an h22 stock head? Stock rods crank so forth. I looked in the h23vtec post and couldnt find anything. I still want daily drivability and not be breaking stuff.
Old Sep 12, 2003 | 08:25 PM
satan_srv's Avatar
Default Re: 11.0.1 cr JE pistons for h23 (95 lude)
An 11:1 H23 piston is way less compression with a H22A head. Maybe 10.5:1 at best.
Old Sep 13, 2003 | 06:04 AM
Default Re: 11.0.1 cr JE pistons for h23 (satan_srv)
Do you think it would still be safe to rev it to the 7200 rpm range of the vtec head? I want toi be able to rev the motor in that range. should I maybe get some good rods too?
Old Sep 13, 2003 | 08:25 AM
importsyn's Avatar
I'd be more worried about your crank.
Old Sep 13, 2003 | 09:14 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude &raquo;</TD></TR><TR><TD CLASS="quote">Do you think it would still be safe to rev it to the 7200 rpm range of the vtec head? I want toi be able to rev the motor in that range. should I maybe get some good rods too?</TD></TR></TABLE>
The fact is it's less reliable. Deal with it or don't do it. Rods will help prevent egging at the high rpms but really your bearings will take a beating. H22a redline is 7400 btw.
I shot peened my rods when I did the H23 VTEC, it was the crank that didn't last.
Old Sep 13, 2003 | 11:54 AM
What were you reving your engine to? Didnt the crank break because you had it knifed. Just wondering...... not trying to be an ***
Old Sep 13, 2003 | 07:15 PM
Is a stock crank good or are they all just really bad for the higher rpms? I really dont think that 7400 rpms is that bad for the crank but I am just an amature&gt; Thanks for the help
Old Sep 13, 2003 | 07:17 PM
satan_srv's Avatar
you can do it, I'm just saying it's not as reliable.
Yeah I had a knifed crank spun to 8500rpms...we were asking for it.
H22a fuel cut is 7800 though it wasn't that far off
Old Sep 14, 2003 | 12:06 AM
Yeah I would not knifethe crank or anythng like that. I only ocasionally get in the 7000 rpmrange but I am a little scared about doing it all the time
Old Sep 14, 2003 | 08:20 AM
satan_srv's Avatar
why do it if you're not going to rev it to where the power is?
Old Sep 14, 2003 | 10:37 AM
you are right satan.
tmrtwo
Feb 13, 2007 03:14 PM
93ludesitec
Aug 16, 2006 08:26 PM
killeri
May 1, 2006 08:45 AM
xxredpreludesixx
Aug 13, 2005 09:01 AM
satan_srv
Nov 19, 2002 09:03 AM
