What could cause MAP Sensor Code?
Old Sep 12, 2003 | 07:58 PM
1BadCvC's Avatar
Default What could cause MAP Sensor Code 5?
Engine threw code 5. I'm guessing and hoping that the problem is from miss-match of wiring harnesses. Any websites have a diagram for what harness goes to what? What other possibilities would cause this code? Any help is very appreciated.
Modified by 1BadCvC at 5:20 AM 9/13/2003
Modified by 1BadCvC at 5:31 AM 9/13/2003
Old Sep 12, 2003 | 09:26 PM
chrisCNL's Avatar
Default Re: What could cause MAP Sensor Code 5? (1BadCvC)
it's either you have no map vacuum or the wiring harness is hooked up wrong... If both of those are hooked up correctly then it's the map sensor. rarely the map sensor would ever go bad.
Old Sep 13, 2003 | 07:01 AM
1BadCvC's Avatar
Default Re: What could cause MAP Sensor Code 5? (chrisCNL)
k, thank ya very much.
BigbamaBen
Oct 4, 2013 02:45 AM
FSS13foxtrot
Jan 20, 2008 06:23 AM
JasonST
Apr 26, 2006 07:36 AM
D C 5
Jun 19, 2005 11:01 AM
chrysler kid
Sep 28, 2004 07:24 PM
