2004 RSX XM radio????????????
I found that the 04 rsx has xm radio as an accessory install.
Does anybody know if it will go into an 03, I work for an Acura dealer but we
can be a little behind with the info....
Thanks in advance.
Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean »</TD></TR><TR><TD CLASS="quote">I found that the 04 rsx has xm radio as an accessory install.
Thanks in advance.
sure it will work with all the parts.. if they havent changed the dash swap out all the components and your good to go.. make sure you get the XM tuner also..
Thanks in advance.
</TD></TR></TABLE>sure it will work with all the parts.. if they havent changed the dash swap out all the components and your good to go.. make sure you get the XM tuner also..
powerline209ek4
Audio / Security / Video
Apr 19, 2008 08:00 PM
