What do you guys think about my set-up?
The motor is a d15, bored 40 over, crank, rods, pistons, and flywheel have all been balanced and lightened. CRX si(d16a6) Head has been shaved, dunno the exact measurement. Port and polish with intake and exhaust mani's matching as well. D16y8 manifold with an h22a4 throttle body(60mm). 4-1 header,"hi-flow" cat. Full cold air intake, greddy exhaust. Tein ha coilover kit, neuspeed front upper and lower, with rear upper and lower strut bars. Suspension techniques front and rear sways. crx si wheels with 195/50/14 falken azenis. Anyone know what else i can add?
I really want to do that soon, but that will be a little while before i get that far. And if the turbo is not enough. Then i am sure i will go b series and use the same turbo setup.
Matt
Matt
7psi = mucho fun !
