Need someone with a h22 helms to give me valve dimensions plz.
I upgraded my h23 with after market vtec valves. I need the length of an h22 valve. If someone has a helms your help would be much apreicated. The dimensions should be under "Valves and Valve Seals"
Thanks
Bobby
Thanks
Bobby
Overall length:
IN: 106.75 mm
EX: 106.95 mm
Head length:
IN: 35 mm
EX: 30
Stem Diameter:
IN: 5.5 mm
EX: 5.5 mm
IN: 106.75 mm
EX: 106.95 mm
Head length:
IN: 35 mm
EX: 30
Stem Diameter:
IN: 5.5 mm
EX: 5.5 mm
I've been going through all your old posts bobby and this one tells the story the best along with a few others on the boards.
You bought some valves for an H23 you were building and you found out that they didn't fit. So you assumed they were H22a valves and you posted here to verify it. Even when you found out that they were not H22a valves, you put them up for sale as H22a valves anyway. And then I was the unfortunate guy that got screwed over by your ****** *** right at the time when I needed money to get my car running.
DO NOT BUY ANYTHING FROM BOBBY SNYDER AKA LUDESLEEP.
I BOUGHT FERREA 6000 SERIES VALVES FROM THIS GUY 6/22/05. WHAT I GOT WAS A FERREA BOX WITH TWO PEICES OF FOAM INSIDE OF IT AND 16 VALVES SCATTERED AROUND THE INSIDE OF THE BOX. THE VALVES DO NOT FIT H22A. I MEASURED THEM AND CALLED FERREA AND FERREA SAID THEY DON'T EVEN MAKE VALVES WITH THE DIMENSIONS OF THE ONES HE SENT ME.
HE WON'T ANSWER MY CALLS TO HIS CELL. I HAVE BEEN CALLING HIS MOMS HOUSE AND SHE HAS BEEN RELAYING MESSAGES FROM HIM TO ME. HE'S A SCARED LITTLE BITCH THAT RIPPED ME OFF FOR $200 AND DOESN'T HAVE THE ***** TO PICK UP HIS PHONE WHEN I CALL IT.
BAD SELLER. THIS GUY IS A RIP OFF ARTIST. DON'T TRUST ANYTHING HE SAYS
ludesleep
Sep 13, 2003 09:26 AM
