Running out of ideas, motor possibly blown?
Old Sep 11, 2003 | 06:36 PM
Steve90HB's Avatar
Default Running out of ideas, motor possibly blown?
I've made a post about this before, and just installed the new dizzy and STILL the same cranking problem. It sounds like its cranking, but almost like something isn't grabbing - the car is an automatic if this matters
how it all started: Me and a friend were driving back from orlando checking out a new car I bought, going about 95 (fast for this motor) - I was pressing on the gas trying to accelerate but I was getting no response... checked the RPMs and it was at 0
so we pull over and try to start it, the noise that it makes is like a
well I don't know, it sounds like it's cranking longer than normal - like wreeeeeeeee wreeeeee wreeeeeee
We have checked the timing belt, it IS spinning and it's not broken
New distributor
ALL the plugs
CAR does have fuel and is getting fuel
toss out any ideas you might have, it's sitting at one of my friends shops and he's getting a little frustrated with it sitting there
OH, and the car was POSSIBLY out/low on oil - but I heard no knocking and there is nothing wrong with the block
Old Sep 11, 2003 | 06:39 PM
Turbo12acer's Avatar
put some oil in, do a compression test and make sure its still good. I would say check timming as well.
Old Sep 11, 2003 | 06:44 PM
VTECorona's Avatar
Default Re: (Turbo12acer)
If you seized it the motor wouldn't crank at all so hopefully it's not a run-out-of-oil issue. Check ur oil and full if needed.. do you have any check engine lights?
Old Sep 11, 2003 | 07:22 PM
Steve90HB's Avatar
Default Re: (VTECorona)
NO CEL lights, well if I ran out of oil.. wouldn't it screw something up? I did put in a couple ounces after it happened... will try a compression test tomorrow, let's keep the ideas comin please
Old Sep 11, 2003 | 07:32 PM
mmuller's Avatar
Mad Scientist
Default Re: (Steve90HB)
are you getting spark?
Old Sep 11, 2003 | 07:33 PM
Steve90HB's Avatar
Default Re: (mmuller)
NEGATIVE on spark, dizzy is fine
Old Sep 11, 2003 | 07:35 PM
mmuller's Avatar
Mad Scientist
no spark?
check main relay, check dizzy again
Old Sep 11, 2003 | 07:37 PM
VTECorona's Avatar
Well you found the culprit, atleast you have somewhere to start now. Check connections, grounds, plug wires, and dizzy..
Old Sep 11, 2003 | 07:42 PM
Steve90HB's Avatar
ok how would I go about "checking" the main relay? I don't have a helms on me
Old Sep 11, 2003 | 07:49 PM
VTECorona's Avatar
do you have access to a multi meter?
Old Sep 11, 2003 | 07:53 PM
Steve90HB's Avatar
nope, my dad is livin in kansas and took all the good stuff with him
I'm looking at the helms (I found one online) just possible if it could maybe be the ignition timing? It sounds like it could be possible...
edit: ok nevermind on that idea
91tegrals's Avatar
dude if you know youre not getting spark the you should know were to start looking.and the motor would not start if it was locked or had somthing internal fucked up....
Old Sep 11, 2003 | 07:59 PM
Steve90HB's Avatar
Default Re: (91tegrals)
I'm not getting spark my first thought was dizzy, OK I am out of ideas - he's bringin up the main relay, etc... the car isn't worth much but I do want to get it running and out of the way spending as little money as possible
trial and error cost money... truthfully I'm hoping someone had this problem before
Old Sep 12, 2003 | 11:42 AM
did you check the ignition module in the dizzy? if your dizzy is ok but module isnt working then change module. but check relay first
jdm91integ
Jun 27, 2014 03:00 PM
slamLOWnBANGIN
Aug 27, 2010 08:29 AM
viet_tec
Dec 12, 2009 09:11 AM
CountryHonda
May 29, 2008 07:01 PM
EntuneCrx
Sep 26, 2005 08:05 AM
