d16z6 crx si w/ stock odb0 ecu can it run a Greddy Turbo???
Like the title says...I want to know if I'll have any issues when I put a Greddy turbo kit on the d16z6 running on a obd0 89 crx si ecu? Or will I have to get a obd0-obd1 conversion harness and a 92-95 ex/si ecu, dizzy,(will I need injectors also?)....Thanx in advance!!
Or an Apex'i S-AFC, using 450cc injectors. I think the greddy kit will fit your setup though, but you'll be stuck with that POS FMU, also you'll probably need a couple MAP bypass valves.
But I'm just wanting to run the blue box, how would I wire that up to the 89 ecu? also am I losing horsepower running the 89 si ecu...should I chip it?
SOHC_TURBO_CIVIC
Sep 11, 2003 06:20 PM
