3in exhuast on a teg
Old Sep 11, 2003 | 05:54 PM
imthedude's Avatar
Default 3in exhuast on a teg
i just want to know how 3 in fits on an integra and if theres any problems
thanks
Old Sep 11, 2003 | 06:09 PM
00VTEC's Avatar
Default Re: 3in exhuast on a teg (imthedude)
you don't need 3" exhaust, unless you're boosting or making some serious horsepower. if you only have simple bolt-on's you're gonna lose on low to mid range. BUT if you really wanna do it, just hook it up with 3" aftermarket cat.
Old Sep 11, 2003 | 06:49 PM
imthedude's Avatar
im getting all my supercharger stuff together so....
Old Sep 11, 2003 | 06:55 PM
DC2Slow's Avatar
Default Re: (imthedude)
it should be fine...try using SS n mandrel bent pipping oh and dont forget the resonators...cuz itll be loud
imthedude's Avatar
i mean i had 2 1/2 on my other teg and that fit ok but im wondering is what is the best exhuast set up for supercharged and i dont need a cat or anything they dont do checks in MI
Old Sep 11, 2003 | 06:58 PM
King_j's Avatar
supercharged? kamikazi (sp?) header.
Old Sep 11, 2003 | 07:02 PM
DC2Slow's Avatar
just find a 3inch magna flow muffler...its the easiest
Old Sep 11, 2003 | 07:30 PM
Steve04SVT's Avatar
Default Re: (DC2Slow)
Check out Thermal Research's 3" setups. They look clean and are designed very well.
Old Sep 11, 2003 | 07:34 PM
InTeGrA B18b1's Avatar
Default Re: (Steve00GSR)
would 2.5 inch be good for supercharger? or 3 inch is better? because w superchargers ppl arent making that much hp as to turbo
Old Sep 11, 2003 | 10:14 PM
B2FiNiTY's Avatar
Default Re: (InTeGrA B18b1)
it doesn't matter how much hp, it matters how much flow you need.
Old Sep 12, 2003 | 09:40 AM
Steve04SVT's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't matter how much hp, it matters how much flow you need. </TD></TR></TABLE>
Well put!
Old Sep 12, 2003 | 09:48 AM
Frito1's Avatar
How much flow he will have depends on how much power he's putting out.
Old Sep 12, 2003 | 12:03 PM
Hites
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imthedude &raquo;</TD></TR><TR><TD CLASS="quote">i just want to know how 3 in fits on an integra and if theres any problems
thanks</TD></TR></TABLE>
3" tip inlet or 3" piping inlet?
Old Sep 12, 2003 | 12:10 PM
quikB18B's Avatar
Default Re: 3in exhuast on a teg (Hites)
Yes it will fit, How much boost are u plannign on running with the supercharger?. I would go with the kamikaze header and maybe the greddy power extremeII(its like 2.75) or something close to that.
Old Sep 12, 2003 | 12:23 PM
MightyMouseTech's Avatar
Just a warning, using a 3" exhaust on a supercharged car is going to be freakin loud as hell. The turbo guys can get away with it because the turbo itself acts a muffler of sorts. Because you don't have the impeller to cut down some of the noise, it is going to be brutally loud. When our shops turbo Civic blew a turbo, we just hooked the header up when we pulled the turbo manifold off. Running it with the 3" Thermal system lasted an entire 5 minutes. As soon as we started it and the windows in the shop started shaking like crazy we realized we had to put the factory exhaust on until the new turbo went in.
Although, to answer your question, the 3" Thermal R&D exhaust fits just fine. But you will notice in their catalog it says for TURBO ONLY.
Old Sep 12, 2003 | 12:33 PM
Chris1091's Avatar
Default Re: 3in exhuast on a teg (MightyMouseTech)
I had no problem fitting my Thermal 3" on my car. It rubbed a bit on the ITR swaybar but no biggies.
Old Sep 12, 2003 | 02:43 PM
imthedude's Avatar
yeah i already have a kamikaze so im planning on doing either 2.5 all the way back or 3 all the way from the header. I had 2.5 header back on my b20 civic with it gutted so i can handle it being all loud plus the teg is not going to be my second car so im not going to be driving it all the time.
UltimX
Jul 7, 2005 03:42 PM
Anubyss
Aug 17, 2004 07:05 AM
haophat
Feb 25, 2004 04:29 PM
Creep
Nov 25, 2002 10:37 AM
