Hatch wont open
my hatch likes to be a pain too...it won't open when it's unlocked...it's a new problem too...but it's not a biggie...the trick i came across was turning the key clockwise (to open) until it makes a pop/click noise and then i quickly use the lever to open it with the other hand...oh yeah...it's for a 98 ls, but maybe you can use my trick
sounds good i think imma go try it...cause my trick already died out..cause i was tuiring it clock wise and opening it at the same time and it worked for a hot second but today it faild...any others?
nope...i don't have any other tricks...i'm just going to keep using that one until it quits working and i have to cave and get it fixed...lol...i'm so cheap.
by the way...good luck to you.
Modified by seeaclearerskyxx at 10:10 PM 9/11/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeaclearerskyxx »</TD></TR><TR><TD CLASS="quote">my hatch likes to be a pain too...it won't open when it's unlocked...it's a new problem too...but it's not a biggie...the trick i came across was turning the key clockwise (to open) until it makes a pop/click noise and then i quickly use the lever to open it with the other hand...oh yeah...it's for a 98 ls, but maybe you can use my trick</TD></TR></TABLE>
i have to do that too.
The toggle switch that releases the latch will tend to stick. You have to move the switch over with your finger to its original position. Otherwise the hatch will not open.
From: Do I look like Michael Bolton from Office Space,, MD, USA
Just a side note...my hatch will not open without the key and that prevented the rest of my stereo from being stolen last weekend. I have the rear hatch cover and a rear strut bar which the theives could not wedge the sub or other equipment between so they left it. Too bad they got away with the amp on the back seat
Alexander
May 24, 2002 01:03 PM
