ATTN: What do you think of this Turbo Set-up?
Old Sep 11, 2003 | 05:05 PM
Fuzion's Avatar
Default ATTN: What do you think of this Turbo Set-up?
This is gonna be my set-up, and keep in mind that only 12lbs@ track until my block is built (fully built). This is my daily driver tell me if i should re-think this as a street car and daily driver. 8-10lbs daily street.
B18B1 Block:
100% stock (under construction)
Trans: GSR w/ ITR LSD
B16 Head:
CTR Cams (not final decesion)
Skunk2 valve springs and ti-retainers
STR Cam Gears
ITR intake manifold
Ecu P72: chipped
9500rev limit
5500 vtec crossover
Others:
hondata s200b
255 fuel pump
550cc injectors
Old Sep 11, 2003 | 05:10 PM
boosted92's Avatar
Default Re: ATTN: What do you think of this Turbo Set-up? (Fuzion)
Looks good to me but use some GSR cams over CTR cams, you should pick up some spool and a few ponies because of less duration, unless you can dial it out with the gears.
Old Sep 11, 2003 | 07:40 PM
JDMs1eeper's Avatar
Looks great... too bad i'll still beat you Just kiddin
Old Sep 11, 2003 | 07:42 PM
tegasaurus's Avatar
Default Re: ATTN: What do you think of this Turbo Set-up? (Typesi2nv)
TI retainers go "bad" after X mileage... i think its about 6000 miles, correct me if im wrong, so you might want to stick with some ITR ones.
saemoonyang
10
Apr 18, 2008 07:04 PM
spuddo01
Apr 1, 2006 08:43 AM
notstock93
12
Jul 31, 2004 08:08 PM
Fuzion
Sep 9, 2003 04:39 PM
GReddySetGO
Nov 16, 2001 07:41 PM
