Reccomended tire pressure for Azenis? for autox..
Old Sep 11, 2003 | 03:12 PM
Blazeone's Avatar
Default Reccomended tire pressure for Azenis? for autox..
I am about to go autoxing this weekend, and i am unsure about the tire pressure in my azenis. They are 215/45/16 on volk te-37's..
thnaks in advance
Old Sep 11, 2003 | 05:35 PM
HondaRcB's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (George Knighton)
I'm on my second set of Azenis, and have been autocrossing with them for over a year. I've found that best pressure to run them is 38 hot in the front and anywhere from 40-44 hot in the rear depending on the course and track surface. Hope this helps.
Old Sep 11, 2003 | 06:19 PM
StageOne's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (redx)
The best pressures we've found running Azenis has been to put the fronts at 36psi. IT seems lower than most people run, but it was amazing the difference in grip when I went from 38 to 36psi. I ran the rears at a much lower pressure, 28psi. But you can also run them higher 42 or so. That is more dependent on your preference and how you like the car to feel. Some prefer the rears higher while others, like me, prefer them lower (Note, for track days I switch and run higher rear pressures as it makes the car more predictable.... go figure)
Your pressures are also dependent on what suspension modifications you have. If you car is very well balanced, you can run similiar front to rear pressures.
So give 36F, 28R a try and see how it is. If the back end is not rotating, drop the psi down a little. I have run as low as 24 with no problems. But as I adjusted the suspension, I was able to raise it up.
Old Sep 11, 2003 | 09:11 PM
arren123's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (StageOne)
I agree. I'm running the 215/45/16 Azenis too.
36 psi in the front is perfect. There is no rollover unless you take he turn too hot.
I'm running 34 psi in the rear and the rear sticks like glue. The only way I can get the rear to step out is if I trailbrake.
High pressures in the front and rear make the car feel too squirly (38 psi f/ 37 psi r)
Old Sep 12, 2003 | 06:14 AM
tilt's Avatar
i have some on 15x6.5 wheels. 42front/38-40back (still workin on the rear)
I have the front at 42psi cuz the turn in is sloppy at lower psi. It's just a characteristic of azenis, but I think wider rims would probably help lessen this problem.
Old Sep 12, 2003 | 06:31 AM
Cosworth's Avatar
I ran 34psi all around and it was fine. I typically have the front 1psi higher than the rear. This was on 7" width-ed wheels.
Old Sep 12, 2003 | 09:00 AM
Chris93Si's Avatar
38f and 36r seems to work pretty well for me, I may try something higher in the rear this weekend though.
Old Sep 12, 2003 | 09:04 AM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I think that everybody's driving style is different, so it's a bit of a hazard to tell somebody else where his pressures should be.
In my personal experience, however, (on road courses) the Azenis on 16x7 wheels do better with <u>lower</u> pressures than you'd expect!</TD></TR></TABLE>
exactly. I tried to search for settings on h-t. I went out and tried them at autocross and they really didnt do much for me.
But like u say, they really do great at lower pressures. Perhaps its due my suspension set up (kyb agx, 435 F 330 R, 19 mm front and rear sways), but at autocross my tires seem happiest with about 31psi in the front, and 20psi in the rear.
Old Sep 13, 2003 | 12:27 PM
IGGY's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (JaeOne3345)
I run 38-40 hot on all four.
Old Sep 13, 2003 | 01:39 PM
6ghatch's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (IGGY)
For auto-x on a 15x7 with 205-50-15. I run 37 front and 40 rear.
Old Sep 13, 2003 | 02:00 PM
IGGY's Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (6ghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6ghatch &raquo;</TD></TR><TR><TD CLASS="quote">For auto-x on a 15x7 with 205-50-15. I run 37 front and 40 rear.</TD></TR></TABLE>
Why are you running a higher tire pressure in the rear? Wouldn't that cause the rear to swing out more in a turn?
Old Sep 13, 2003 | 02:01 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">
Why are you running a higher tire pressure in the rear? Wouldn't that cause the rear to swing out more in a turn?</TD></TR></TABLE>
is that so bad for a car with terminal understeer?
Old Sep 13, 2003 | 05:18 PM
Phoenix_ITR's Avatar
in a front wheel drive car (especially on a tight circuit), terminal understeer is a huge problem. in our race cars, we live by the "loose is fast" rule and it works for us. throttlesteer is a wonderful thing
Old Sep 13, 2003 | 05:21 PM
uNF$@#!'s Avatar
Default Re: Reccomended tire pressure for Azenis? for autox.. (delinquent)
more narrow tires in the rear also help with the understeer issue, though, i dont know if that would cause terminal oversteer, which is not so fun
Old Sep 13, 2003 | 05:25 PM
Default Re: Reccomended tire pressure for Azenis? for autox.. (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">more narrow tires in the rear also help with the understeer issue, though, i dont know if that would cause terminal oversteer, which is not so fun </TD></TR></TABLE>
i actually ran 205s up front and 195s in the rear for a while and loved it.
EJtypeR
Mar 22, 2005 10:49 AM
RAB
11
Apr 21, 2004 03:26 PM
mitsuman
Jan 22, 2003 09:12 PM
flip1199
Jan 13, 2003 02:27 AM
momo48
Jan 23, 2002 06:25 PM
