89 car - 93 motor please help!
Old Sep 11, 2003 | 01:06 PM
coolusername's Avatar
Default 89 car - 93 motor please help!
i bought a 93 civic vx vtec-e motor from a friend that did a swap. my car is a 89 civic lx with a d15b2 engine that is horribly dead. i put the d15z1 engine in my car and used my dpfi intake and my original distributor. the car will start but will not run unless u have foot on gas, but if i remove the #1 plug and leave it out the engine runs. as if the exhaust valves are stuck on the head. i am wondering if my d15b2 head will work on the d15z1 block. or if anyone know what i should do. thanks!
Old Sep 11, 2003 | 11:23 PM
Redline130's Avatar
Default Re: 89 car - 93 motor please help! (blue89civic)
Maybe you have a wiring issue. Is the ecu flashing any codes? I assume you are using your dx ecu?
Old Sep 16, 2003 | 11:12 AM
Default Re: 89 car - 93 motor please help! (Redline130)
i am using stock ecu. i will check for codes. thanks
mgreene
42
Mar 2, 2014 12:00 AM
Ekasey
Apr 15, 2008 08:03 AM
bigdracing
Jul 5, 2006 06:07 PM
coolusername
Jul 29, 2003 06:55 AM
