DELSOL ultimate power plant
has any one here put a H22 into there delso and put a supercharger on the motor does it fit and what problems would you run into with the swap thanks again
an h22 in a sol
well the first problem is the way the motor rocks when u shift u wouldnt get any traction.2nd the weight of the motor too. the suspension is not made for that heavy of a motor.
Then take car around a corner with theat power and weight and u more than likely wont make it around. But hey just thought i would let you know what i know
its all up to you
it would be good if you just want a straight line run........Power
its all up to you
I think there is a 95 Civic swap in the latest Sport Compact Car magazine. Its the Sept issue and there is not room for AC or power steering.
[Modified by sol-man, 3:37 PM 8/21/2001]
275Performance
Apr 30, 2003 05:22 PM
