ls/vtec rod issues
Old Sep 11, 2003 | 11:26 AM
Mr. Softee's Avatar
Default ls/vtec rod issues
if the main weakness in most ls/vtec's is rod bolt failure or rod stretch... how can thi sbe prevented without upgrading the rods?
arp rod bolts alone do the trick?
sam
Old Sep 11, 2003 | 12:47 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: ls/vtec rod issues (94goldjungsr)
ARP Rod Bolts.
Shotpened LS Rods.
Actually depends how high you wanna rev, I've seen people use just the bolts, but I will be doing the rods as well, better safe than sorry.
Old Sep 11, 2003 | 03:06 PM
Mr. Softee's Avatar
Default Re: ls/vtec rod issues (tommySI)
just want to go to 8
Old Sep 11, 2003 | 03:08 PM
RS Machines's Avatar
use the arp's and get the rods re-sized
Old Sep 11, 2003 | 03:11 PM
HONDABROMANDUDE's Avatar
Arp bolts will be fine. Before I rebuilt my ls vtec, I was using stock rods with arp bolts and I was using an ecu done by locash and he didnt put a rev-limiter on it. Whenever I would miss a gear it would shoot up to 9k+ and My rods were fine. One time I hit 9950 according to my V-AFC and the rods never let go, so ARP will be fine up to 8k.
Also a friend of mine is running stock+ ARP's in his ls/vtec, takes it to 9200 daily!
Modified by itec311 at 12:22 AM 9/12/2003
Old Sep 11, 2003 | 06:50 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: ls/vtec rod issues (itec311)
Just out of curiosity what happened that you have to rebuild it now?
Old Sep 11, 2003 | 10:22 PM
Mr. Softee's Avatar
nothing just considering upgrading
Old Sep 11, 2003 | 10:52 PM
ELESVEE's Avatar
Like the other guy above I'd recommend arp bolts with shotpeened rods. I had that with b16 pistons in my last lsv set up and it was nice with my old 402's
Old Sep 11, 2003 | 10:53 PM
JDogg's Avatar
Default Re: ls/vtec rod issues (ELESVEE)
imo the rod will break long before the bolt... we were making 185hp and turning 8500 daily in our stock bottom b20vtec for about 25k miles with no problems from the rods or the rod bolts
Old Sep 11, 2003 | 11:53 PM
F1Spec's Avatar
i rev 10k all day long @ the track.
shotpeened rods with arp bolts.
n/a though. if i were running boost, i'd upgrade the rods.
chrisff521
May 28, 2013 11:07 AM
170whp-B16a
Jun 8, 2010 11:31 PM
killerpenguin21
Jul 19, 2006 05:01 AM
Power Rev Racing
Sep 22, 2004 07:34 PM
skribblah
63
Jul 11, 2003 10:29 AM
