90 Honda Accord to a 98 GSR Motor Swap
I have recently purchased a 98 GSR Motor, Transmission, CV Joint, ECU, and Wire Harness. The built motor has been dyno'd at 286hp! It comes with the motor mounts also. It was recently in a Hatchback CIVIC. My 2 questions are: Will I need anything else? and Will I need a conversion kit for the motor mounts?
It's got true turn pulleys, high-performance cam gears high flow fuel rails, venom injectors, titanium valve springs, dc sport header, and port and polish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j90honda »</TD></TR><TR><TD CLASS="quote">It's got true turn pulleys, high-performance cam gears high flow fuel rails, venom injectors, titanium valve springs, dc sport header, and port and polish.</TD></TR></TABLE>
that will not give it anywhere close to 286 hp
you would be lucky to see 200 hp
GSR swap into an Accord is a waste. If you have a built GSR, buy a hatch. Period. The reason you own an Accord is to take advantage of the higher displacement Honda motors. That is unless you decided to make a huge turbo kit that took up the entire engine bay, because otherwise there's gonna be enough room for two midgets in there.
Aplogy to all short people.
post the dyno sheet, I am very skeptical
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickercuttingcom »</TD></TR><TR><TD CLASS="quote">Have fun putting that thing in!
haha!
Nate.</TD></TR></TABLE>
plus one?
haha!
plus one?
id like to see a dyno sheet as well...they prolly jipped you and told u what it could reach with a turbo kit on it, but it sounds like u got no turbo kit...might wanna start savin up a few for one if ur gonna want to back up that number...
mycivichb
Oct 30, 2004 04:51 AM
