compression
Old Sep 11, 2003 | 07:00 AM
jeremy.'s Avatar
Default compression
what do you think my compression is with a gsr block and b16 head with jdm itr pistons? will this be enough to push toda spec b's or c's? or should i get a thinner head gasket to raise compression?
Old Sep 11, 2003 | 09:53 AM
zigs's Avatar
Default Re: compression (ek_jeremy)
With a gsr block, b16 head and JDM itr's your compression should be around 11.1. It wouldnt hurt to go higher with toda b's or c's. Other options with oem pistons would be CTR pistons would put you around 11.7 or if you wanted to go inbetween jdm P30 pistons should put you around 11.4.
AssPenny
Jan 13, 2014 04:51 PM
EJ1_203
10
Sep 28, 2007 04:28 PM
panykus
15
Sep 19, 2004 08:55 PM
civic ex si
Feb 27, 2004 08:36 AM
NightHawkC5
Feb 23, 2003 12:50 PM
