88 crx si b16a gas mileage is bad
Old Sep 11, 2003 | 05:57 AM
b16acrxer's Avatar
Default 88 crx si b16a gas mileage is bad
what would cause bad gas mileage...b16a is running swell/normal. just seems to be using more gas now , than it had in the last 4 months.
Old Sep 11, 2003 | 06:02 AM
HT Chaplain's Avatar
Loved
Default Re: 88 crx si b16a gas mileage is bad (b16acrxer)
when the last time u had a tune up ex. sparkplugs, fuel filter ,cap rotor and the main thing 02 sensor and pcv valve.
Old Sep 11, 2003 | 07:17 AM
b16_madman's Avatar
Default Re: 88 crx si b16a gas mileage is bad (legutki)
ive forgotten where the pcv valve is....
I think I could use two new o2's and the pcv valve.....
17-20mpg's in the city
Old Sep 11, 2003 | 10:03 AM
type Gendy's Avatar
What and where is a pcv valve?
Old Sep 11, 2003 | 10:49 AM
Doctor CorteZ's Avatar
Default Re: (sick hatchem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem &raquo;</TD></TR><TR><TD CLASS="quote">What and where is a pcv valve?</TD></TR></TABLE>
positive crankcase ventilation , its usually found between the intake runners and has a hose attached to it that terminates at the plenum.
basically it takes any blowby oil and inserts it back into the combustion chamber to be burned off reducing your octane rating and robbing power.
catch cans are your friend.
Old Sep 11, 2003 | 03:16 PM
type Gendy's Avatar
So do you replace the pcv valve, or clean it? OR do you remove it for better gas mileage.
Old Sep 11, 2003 | 03:19 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem &raquo;</TD></TR><TR><TD CLASS="quote">So do you replace the pcv valve, or clean it? OR do you remove it for better gas mileage.</TD></TR></TABLE>
replace it! It's cheap...
EK9 BEEZLER
Jul 28, 2005 05:22 PM
oz`Vtec
May 18, 2005 05:18 PM
Smeeg Heed
Apr 14, 2004 08:49 PM
professorman
Jun 1, 2003 03:41 PM
