HID - question related to Philip 6000K Kit....
Old Sep 11, 2003 | 05:14 AM
Nuts's Avatar
Default HID - question related to Philip 6000K Kit....
I have search on the archieve (which answered most of my questions) but I still have 2 questions with no solid answer.
1) Are those bulbs interchangable with lower Kelvin (K) Philips bulbs?
2) Based on this article http://faq.auto.light.tripod.com/hl-hid-bulbs.htm 4300K is actually brighter than 6000K, is this true? and if that's the case, is there a reason why 6000K is much more expensive than 4300K?
I don't know if this is the appropriate forum to post this but based on the search in the archieve, I know a lot ITR guys have expereince with HID. If mod. think it's more suitable for other fourm, please move this as needed.
Old Sep 11, 2003 | 05:22 AM
xanctus's Avatar
Default Re: HID - question related to Philip 6000K Kit.... (01-1194)
I am not sure about interchangeable or not to the lower kelvin, but I did once send email to (forgot the name of the store) that they are saying it is interchangeable as long as same brand.
Regarding brightness, I think it has been discussed so many times and 4300K is much brighter than 6000K, and I dunno why 6K is more expensive
Old Sep 11, 2003 | 06:04 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: HID - question related to Philip 6000K Kit.... (xanctus)
6000k is more expensive because its a popular upgrade for peole with HID's. It may cost a little more to fix not sure.
As for interchangeability generally if its a phillips kit you can use a phillips bulb regardless if its a different temperture rating (IE if you have Phillips 6000k's you can use 4300-4100k PHILLIPS builbs and vice versa).
Also if you do go with a 6000k kit make sure the bulbs are ultinons. its not a phillips 6000k bulb if its not a ultinon.
Old Sep 11, 2003 | 06:12 AM
Nuts's Avatar
Default Re: HID - question related to Philip 6000K Kit.... (Apex i ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Also if you do go with a 6000k kit make sure the bulbs are ultinons. its not a phillips 6000k bulb if its not a ultinon.</TD></TR></TABLE>
How do you tell if it's a ultinon?
Old Sep 11, 2003 | 06:46 AM
Rory Breaker's Avatar
You should be able to swap the bulbs, no problem.
Here are some pictures I popped up of my 6000ks:
https://honda-tech.com/zerothread?id=616071
Everyone on the board is quick to flame and say "anything over 4300k is garbage"...dont listen to the bandwagon. Do what you want...technically, 4300k is the brightest, but some people do want a bit of bling to their HIDs. I can understand why people wouldnt get 10000k for example, but 4300/5300/6000k...whatever.
Old Sep 11, 2003 | 06:50 AM
Apex i ITR's Avatar
It will say it on the package.
It will be a clear bulb (don't get a bulb that's colored).
The cyrstals that line the bulb will be a purple/blue color.
And I agree with newgsrdriver. A lot of people don't like 6000k's but in my car they look bright white with a slightly purple hue to it. Its not ricey @ all parked next to a factory HID equipped car they look almost the same (like on the reflector OEM HID equipped cars).
My buddy also has the 5000k kit from xenondepot and he actually ended up liking mine more.
Old Sep 11, 2003 | 07:42 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
I have a 7000k kit and love the color! Yes it is true you get more light from the 4100k-4300k kit but the 5000k-7000k kits still give you a major performance gain over stock lighting! **** the hype get what you like!
oh KSERIES
Nov 14, 2005 02:17 PM
TemperdSoul
Sep 18, 2005 05:16 PM
Jx3069
Oct 8, 2003 07:39 PM
