AN-R Question
Old Sep 10, 2003 | 09:43 PM
vtecman253's Avatar
Default AN-R Question
what is the difference between the regular 4-1 and the crazy *** mo fo snail style one? also, their website advertises them for $530 shipped. is that a deal or would cermaic coating($180) or stainless steel($250) be necesary for good daily driving usage?
Old Sep 11, 2003 | 05:31 AM
vtecman253's Avatar
Default Re: AN-R Question (vtecman253)
bumparoo
Old Sep 11, 2003 | 06:05 AM
Mr Hammond's Avatar
a/k/a Jomo
Ground Clearance.
Old Sep 11, 2003 | 06:06 AM
quikyEG's Avatar
yup the compact one is for ground clearance.....but it does look badass, i would have got it if i knew they definently made a lot of power
Old Sep 11, 2003 | 09:20 AM
Snail EG's Avatar
Default Re: (quikyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikyEG &raquo;</TD></TR><TR><TD CLASS="quote">yup the compact one is for ground clearance.....but it does look badass, i would have got it if i knew they definently made a lot of power</TD></TR></TABLE>
actually, both headers have the same ground clearance. the difference in them is that the compact one would fit an EF chasis with b-series and it also fit b-series using the full size integra radiator. For the standard header, you would have to use the civic's half size radiator.
Old Sep 11, 2003 | 11:57 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (Snail EG)
to me for not readingt the whole post. I thought he was asking the diff. between the AN-R "crazy snail looking one" comapred to other top brand ones not the other AN-R. Does the other AN-R the one with the long straight primaries merge before the oil pan as well?
Old Sep 11, 2003 | 12:10 PM
Snail EG's Avatar
Default Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote"> Does the other AN-R the one with the long straight primaries merge before the oil pan as well?</TD></TR></TABLE>
Yes, the collector is placed above the oil pan for increased ground clearance. The ground clearance on our header is as good as stock ground clearance, if not better.
Old Sep 11, 2003 | 01:01 PM
Casey's Avatar
so what kind of extension am i going to need to hook the header up? i used to have the jdm 4-1 itr with a test pipe, the test pipe is still on, so in comparison to the jdm itr, is the an-r shorter or longer, and by how much? thanks
Old Sep 11, 2003 | 01:05 PM
Snail EG's Avatar
Default Re: (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">so what kind of extension am i going to need to hook the header up? i used to have the jdm 4-1 itr with a test pipe, the test pipe is still on, so in comparison to the jdm itr, is the an-r shorter or longer, and by how much? thanks</TD></TR></TABLE>
We usually allow enough piping so that it can be cut down to size to fit onto a test pipe/cat.
Old Sep 11, 2003 | 01:24 PM
Casey's Avatar
sounds good, thanks. Hope it gets here soon, the anticipation is killing me
turkishEF
Aug 18, 2008 11:26 AM
midnite_B16
Mar 15, 2007 09:33 PM
Sumslapper
Feb 28, 2007 05:46 AM
lak8
Jul 26, 2005 05:22 AM
SimbaDogg
Jan 12, 2004 10:55 AM
