WILL A 1990 DIZZY D15 DISTRIBUTOR WORK ON MY 89 1.5 LITER DX HB???
Old Sep 10, 2003 | 08:43 PM
ozy69's Avatar
Default WILL A 1990 DIZZY D15 DISTRIBUTOR WORK ON MY 89 1.5 LITER DX HB???
I am going in for a surgery on Friday from totaling my hayabusa on the 25th
and need this info before I go in.
I have a distributor that I bought from someone on this sight. A dizzy D15 for my 1989 1.5 liter DX HB it looks the same but does not have the condenser on it. Instead there is a rubber plug where it would be? is this the wrong distributor? Can I Just put the old condenser on it? And is it possible to put the distributor in 180 degrees out? and or is there procedure to put in correctly?
Thanks in advance
Old Sep 10, 2003 | 09:40 PM
Vinceg99's Avatar
Default Re: WILL A 1990 DIZZY D15 DISTRIBUTOR WORK ON MY 89 1.5 LITER DX HB??? (ozy69)
hmm? I really didnt think there was a difference between 89 and 90 DX dizzys??
As for putting it in 180 degrees off yes it is possible.
Old Sep 10, 2003 | 09:45 PM
Louie B.'s Avatar
some have condensors and some don't... if the plug is the same then it should work fine. and as far as putting it in, there is only one way. It can't go in backwards.
92coupe
12
Nov 5, 2010 08:30 PM
crxben
Oct 25, 2006 02:44 PM
classciv
Apr 2, 2006 03:30 PM
ozy69
21
Dec 3, 2003 11:50 AM
