Throttle body
Old Sep 10, 2003 | 08:12 PM
Space Boy's Avatar
Default Throttle body
I am rebuilding a b18c1 bottom end with itr pistons(usdm) and mating it with a 97 itr head and itr IM. I was planning on using my gsr throttle body. I may be able to get ahold of a itr throttle body. Is this worth while to get or not. The reason why I ask this is because the itr real time tegs had a restrictor plate(I think 58mm). I don't know much about this...I have done a search but most of it surrounds 70mm...way to big for my application
Old Sep 10, 2003 | 08:40 PM
T4eg's Avatar
Default Re: Throttle body (Space Boy)
I would try to get ahold of a ITR throtle body.
Old Sep 10, 2003 | 10:09 PM
NA gs-R 05 C
Guest
Posts: n/a
you should probaly go ahead and try to get ahold of the itr TB.
Old Sep 10, 2003 | 10:15 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: Throttle body (NA gs-R 05 C)
in the N/A fourm they did a huge test on the differances between 60/62/64/68mm TB's and the best gain was 2.3whp @ 8500rpms, the rest of the graph was almost the exact same...I would say if you can get one cheap go for it...
Old Sep 10, 2003 | 10:26 PM
mmuller's Avatar
Mad Scientist
Default Re: Throttle body (92 civic VX B18c)
with your mods, you wont see a difference, i would say spend the money on something else.
TomCurllyFry
Mar 18, 2014 01:16 PM
Nick MC
Nov 25, 2005 06:18 PM
gt35r
Jun 19, 2005 10:41 PM
94hybridcoupe
Apr 13, 2005 05:36 PM
