BEST 6.5's for midbass for 00 INTEGRA without TOO much modification/hacking ? ? ? ? ? ?
Old Sep 10, 2003 | 08:05 PM
rodimus's Avatar
Default BEST 6.5's for midbass for 00 INTEGRA without TOO much modification/hacking ? ? ? ? ? ?
powered by JL 300/4 to front component seperates i think and rear
coaxials
rodimus's Avatar
Default Re: BEST 6.5's for midbass for 00 INTEGRA without TOO much modification/hacking ? ? ? ? ? ? (EVOL)
nothing over 600 bucks preferably
Old Sep 10, 2003 | 08:50 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Just midbass no tweeter? Boston Pro 6.5! I hate these threads!!! Go listen to them yourself and pick the ones that sound the best to you!
Old Sep 10, 2003 | 08:52 PM
rodimus's Avatar
Default Re: BEST 6.5's for midbass for 00 INTEGRA without TOO much modification/hacking ? ? ? ? ? ? (arizsun
uhhh...if you hear em on the wall of an audio store..it's not the same..
and that doesn't mean they fit inside my teg w/out too much hacking.
not every store has focals, image dynamics, etc to demo
Old Sep 11, 2003 | 08:05 AM
ArizSun21's Avatar
For the rear of the car I just made new holes in the plastic trim ring and put a foam linner between the speaker and the plastic. This so far makes no weird vibrations or sounds. For the front I used a 3/4" MDF trim ring and that works perfect. I know what you mean about every store not having each piece of equipment. Here is another idea...find stores that offer a return policy even if the speakers are installed and try out a couple sets at a time. I had MB Quarts in my car before but I hated the sound so after hearing most speaker brands my ears liked the tone of the Boston Pro's so I went with them.
Old Sep 11, 2003 | 08:06 AM
ArizSun21's Avatar
Also I am running a component set front and rear but using the coax mount system for the tweeters. Sounds sweet
Old Sep 11, 2003 | 01:31 PM
Wacked2882's Avatar
I love the new Polk DB's. About 160 bucks at circuit city and they rock. You can turn them up full blast with no distortion. If you want even better check out the older model Polk Momo's they are about 250.
Old Sep 11, 2003 | 01:34 PM
rcurley55's Avatar
New User
I'm highly confused as to what you want....do you want to take your existing comp set and swap out the mids, or do you want to supplement your current comp set by adding dedicated midbasses?
So which one is it....
Old Sep 11, 2003 | 07:20 PM
BADGUYNY's Avatar
Hands down I would go with MB Quarts their component sets are amazing good quality. I would get the 6.5's in the Premier Series. they are ruffly between 450-550 depending where you get it from
Old Sep 11, 2003 | 08:10 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">I'm highly confused as to what you want....do you want to take your existing comp set and swap out the mids, or do you want to supplement your current comp set by adding dedicated midbasses?
So which one is it....</TD></TR></TABLE>
i only have stock right now.
i want components up (6.5 and tweeter) front and coax's in the back.
Old Sep 11, 2003 | 09:50 PM
rcurley55's Avatar
New User
what are you doing for a sub/subs? That amp could power a whole, simple system nicely....
Old Sep 12, 2003 | 07:03 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arizsun21 &raquo;</TD></TR><TR><TD CLASS="quote">Just midbass no tweeter? Boston Pro 6.5! I hate these threads!!! Go listen to them yourself and pick the ones that sound the best to you! </TD></TR></TABLE>
I just bought a set of these yesterday..
I used to be a DIEHARD MB Quart fan.. Used nothing but them on my last 2 vehices for mids/highs.. But, I must admit, I preferred the sound of the Boston's over the MB Premiers..
Old Sep 12, 2003 | 10:51 AM
Quad-Damag's Avatar
Go with some MB Quartz those things hit like what
Old Sep 12, 2003 | 03:16 PM
TraKtioN's Avatar
kicker RMB6
Old Sep 12, 2003 | 05:19 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcurley55 &raquo;</TD></TR><TR><TD CLASS="quote">what are you doing for a sub/subs? That amp could power a whole, simple system nicely....</TD></TR></TABLE>
i used to have a 500/1 with a 10W7 till it got stolen
i'm prolly gonna replace it with a 1000/1 to a 12w7...
depends if i can still use a portion of my trunk or not...right vteg? lol
Old Sep 12, 2003 | 05:25 PM
ArizSun21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
I used to be a DIEHARD MB Quart fan.. Used nothing but them on my last 2 vehices for mids/highs.. But, I must admit, I preferred the sound of the Boston's over the MB Premiers..</TD></TR></TABLE>
Good choice!!! Play around with the axis and coax mounting switch along with the db settings for the tweeters.
Old Sep 22, 2003 | 01:08 AM
rodimus's Avatar
n e 1
else?
Old Sep 22, 2003 | 01:10 AM
rodimus's Avatar
n e 1
else?
Old Sep 22, 2003 | 01:01 PM
PupaScoopa's Avatar
There aren't many high quality component sets that'll fit your doors without some modification. Either trim rings that bring the speakers too far our to cutting the door (metal) panels open a little to fit the baskets.
I have the MB PSD 216 set. I have the tweeters at -9db and bass on the head unit turned almost all the way up to make 'em sound good. The lower mid range is weak, though the upper mid is sooooo rich.
I'm considering trying some Diamond Audio HEX components to see if they'll get better midrange... or just some kickpanels and some 6's or 8's in them.
toshko321
Audio / Security / Video
23
Jun 14, 2011 08:08 PM
im_the_teacher
Jun 26, 2003 08:32 AM
dip-set
10
Feb 24, 2003 05:41 PM
ALF
11
Aug 24, 2001 12:50 PM
frankoma
Jun 7, 2001 02:50 PM
