Does anyone know where to find a JDM B20 for a 3rd gen prelude?
Old Sep 10, 2003 | 06:59 PM
prelude2004's Avatar
Default Does anyone know where to find a JDM B20 for a 3rd gen prelude?
Apparently the JDM B20 makes 160 hp, and if the H22 swap proves too costly, then I want the B20. Where can I get one?
Old Sep 10, 2003 | 08:29 PM
19924ws's Avatar
http://www.jdmhondaparts.com
Old Sep 10, 2003 | 08:43 PM
This is not the CRV engine- this is the Prelude engine.
Old Sep 10, 2003 | 10:37 PM
Kaspin's Avatar
try http://www.nippon-motors.com
Old Sep 11, 2003 | 03:51 PM
user 9782082308's Avatar
Default Re: (Kaspin)
Nippon Motors hasn't had any in the past 6 months, I've checked. The b20a5 is JDM Prelude, b20a3 USDM, and b20b is CRV. Also the b20a5 is 145hp. I believe the only diff between the a3 and a5 is the compression highth of the piston.
Nice job with finding out about this engine! I've never knew it existed. Where did you find out about it????????
Modified by racerx at 8:14 PM 9/11/2003
Modified by racerx at 8:15 PM 9/11/2003
Old Sep 11, 2003 | 06:14 PM
I found out about it in another forum. The difference between the USDM B20A3 and B20A5 is that the A3 is carbureted, and the A5 is fuel injected. I should know, cuz i have an A3. Does anyone know what other engines can go into this car?
Old Sep 11, 2003 | 07:06 PM
Default Re: (prelude2004)
I stand corrected.
Unless you're comfortable with fabrication, no other engines will fit. Thats why its called the bastard b. However, I have found that Eagle has a stroker kit advertized for the b20a.
Old Sep 13, 2003 | 07:06 PM
what is the website or phone# for Eagle?
Old Sep 13, 2003 | 10:41 PM
After some research and realizing that I chased my tail, I've come to this conclusion. The importers I've talked to say that the JDM b20 with 145hp is a Prelude engine but I'm thinking differently now. I believe the engine you're talking about is the same engine 3g Luders have installed into their cars. You'll need to mix and match allot of things thats not normally needed on a typical swap. Go to the first site for a detailed description on how to get this b20 usdm friendly so you don't have to import stuff like the timing belt. The other three are 3g Lude sites. I know UT-34 and Daily Interlude from Team Interlude did a JDM b20 swap so they'll be better able to help you. If they didn't use that same Accord engine, post back cause I've got some other ideas that could help you to swap that engine into the 3g.
http://3geez.com/showthread.php?threadid=5907
http://www.teaminterlude.com/main.asp
http://www.3rdgenprelude.com/p...x.php
http://www.preludepower.com/phpBB2/portal.php
BTW, the engine is 160ps. 1hp= 1.1ps making the engine 145hp.
Old Sep 14, 2003 | 01:49 AM
caLiH22A's Avatar
Default Re: (racerx)
This may not be much help but I found a JDM B20A5 on the net...
http://cgi.ebay.com/ebaymotors...33615
It's basically just the longblock, and they claim it has between 30k-40k miles.
Old Sep 14, 2003 | 05:16 AM
kablamo's Avatar
Default Re: (caLiH22A)
JDM B20A (fuel injected) is in the 87-90 preludes in japan (3rd gen)
it is 142hp and is basically just setup to run on higher octane gas than available in north america. to get it to run good and pass emissions you must slightly change the timing.
as for its availability, it's hard to come by. most engine suppliers can get it, but it takes time. there are a lot less out there than B16's... gotta keep your eyes open on this one.
Old Sep 14, 2003 | 01:49 PM
Tell me. I need all the help I can get.
SPIKE'S91CIVICSI
Mar 7, 2009 04:02 PM
threenuts84
Aug 28, 2007 02:41 PM
streetcartuner
12
Jan 7, 2007 03:49 PM
3gmodifier
Jul 31, 2006 04:07 PM
red civic standard
Sep 21, 2003 08:28 PM
