b20 stock reving capabilites??
Old Sep 10, 2003 | 05:16 PM
turbociv's Avatar
Default b20 stock reving capabilites??
what can I rev a stock b20 bottom end to without having to worry. would 8200, be wayt too much??? just looking for opinions and your experience. I spun a bearing in my built lsvtec and was just looking for somthing to get me by until the season is over.
Old Sep 10, 2003 | 05:29 PM
TECH43 RACING INC.'s Avatar
Default Re: b20 stock reving capabilites?? (turbociv)
8200 is about the limit.
Old Sep 10, 2003 | 05:42 PM
desert eagle's Avatar
Default Re: b20 stock reving capabilites?? (TECH43 RACING INC.)
omniman told me 8200 - 8400 on stock rods. i shift @ 7500 with stock b16 head. omniman pretty respected on this site so ill take his word for but my cams dont make power up that hi so i have no reason to go that hi.
Old Sep 10, 2003 | 05:43 PM
turbociv's Avatar
yea just need a quick fix to end the season here in buffalo. snow will be here in about 2months. so 8200 is the limit. After revving the **** outta my last motor I want more of a stock redline this time. I am just wondering how my crower stage3's are going to react to that bottom end.(valve clearance and low compression wise).
Old Sep 10, 2003 | 05:58 PM
turbociv's Avatar
is that stock rods and rod bolts??? thats what I am talking about. I am talking about a completely unaltered b20 bottom end.
Old Sep 10, 2003 | 06:02 PM
Default Re: (turbociv)
8200 is on stock internals. the cams would like more compression, but it will be ok. you must machine bigger valve reliefs on in. and ex. for the vtec cams.
Old Sep 10, 2003 | 06:07 PM
turbociv's Avatar
machine the pistons?? I will have to clay the motor before I go ahead and run it, thats not a problem. I didnt think I would have a clearance problem.
Old Sep 10, 2003 | 09:00 PM
trust. YOU HAVE to either put some forged pistons with the correct valve relief cut or grind the ones in ur block. if kissthe whole engine goodbye! i wasnt warned about piston to valve clearnce when got my 1st b20 vtec. on my second now. learned alot and do my own work. yeah and i did it with 402 cams smaller cam.
when mine gave out a valve just couldnt take anymore, broke got bang up until my #1 piston shattered pretty much in half due to the valve going through it. 3 out my 4 cylinders got damaged. after going through the piston it bounced of the crank and made it through the block. total loss waste of an engine. i dont wanna see that **** happen to anybody. i only had that engine for about 3 months or so.
Old Sep 10, 2003 | 09:25 PM
MikeMAN's Avatar
i had a stock bottom end in my b20vtec, 8200 daily
mike
boostnubII
Mar 22, 2012 11:54 AM
rEnZ94tEgGy
Oct 5, 2008 06:18 AM
boostnubII
Nov 16, 2006 06:50 PM
boostnubII
Nov 16, 2006 06:48 PM
TurboJesse
11
Jul 20, 2005 12:56 PM
