Anyone have a good resource for injector flow rates?
Not a website, but I know Hondas. D series & B series are 240cc, 92-96 'lude are 310, new body style lude is 290, F series SOHC is 240, ZC is 240.
Thanks guys, do you know what the rates are on some C27A1 Legend injectors? The junkyard here sells injectors for five bucks each and has a bunch of legends.
[Modified by clockworks, 11:22 PM 8/20/2001]
..not all injectors are compatible w/ varying obd systems.
You have to be aware of what the impedance leve and resistance level is!
For example, obd 1 h22 inj's are peak and hold and obd2 are saturated, and since they have varying impedance levels you would need to use a resistor pack to get the peak and hold type to work in a saturated system, and if your injectors are like all b-series injectors, they are saturated, and you need to be sure if the injectors your getting are the same..
Good luck..
Good luck..
I always get this mixed up; saturated uses high impedence injectors with no external resistor and peak and hold uses low impedence with an external resistor box? If so, then yeah, the C27A1 injectors are peak and hold, I can get the resistor pack too.
Greg
Greg
si90rex
Sep 8, 2006 05:33 AM
