differences in tire width?
Old Sep 10, 2003 | 02:51 PM
razersharp's Avatar
Default differences in tire width?
I have Volk CE28's ready to go on except the tires... my rim size is 17x7.5 and I am getting yokohama parada spec-2 tires for sure... but there are two different sizes that i can choose from and i dont know how each will effect the car and how it effects performance/handling... the two size options are 205/40/R17 and 215/40/R17
Old Sep 10, 2003 | 03:59 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: differences in tire width? (razersharp)
wider tyres provide a bigger contact patch, BUT with the wider patch and the same ratio your rotational diameter will increase, inhibiting acceleration and throwing your speedo readings.
stan
Old Sep 10, 2003 | 04:00 PM
poison's Avatar
Both of them will fit.
The difference between the two of them is that the 205/40ZR17 tire is 10 mm shorter in width than the 215/40ZR17.
Old Sep 10, 2003 | 04:36 PM
Cynical 1's Avatar
Default Re: differences in tire width? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Both of them will fit.
The difference between the two of them is that the 205/40ZR17 tire is 10 mm shorter in width than the 215/40ZR17.</TD></TR></TABLE>
The 215/40's are also a taller tire. Sidewall height is 40% of 215.
Old Sep 10, 2003 | 04:44 PM
Power5hift's Avatar
Go with 215/40/17
-jacob-
Oct 23, 2008 11:04 AM
Platinum.Skillz
Oct 31, 2007 11:52 AM
realis9
Jul 9, 2007 09:30 AM
mjH22
May 6, 2006 02:21 PM
RGoose18
Dec 8, 2005 10:31 AM
