h23 compression and spark plug question
I ran a compression test today and hit about 180 across all four cylinders. Is this normal. also when i did this i noticed all my spark plugs were running very hot. as in the ends were a bright white color. What is the proper spark plug for a h23? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI »</TD></TR><TR><TD CLASS="quote">I ran a compression test today and hit about 180 across all four cylinders. Is this normal. also when i did this i noticed all my spark plugs were running very hot. as in the ends were a bright white color. What is the proper spark plug for a h23? Thanks</TD></TR></TABLE>
180 is normal yes, check this link out for reading spark plugs
http://www.buckeye-illinois.com/sparkplugs.htm
