rear mount for b16? inserts for stock mounts?
I have a b16 in my 90 civic si with stock mounts and I recently put polyurethane glue on both of the the side mounts, they felt pretty good for a while, but now it seems the strength of the side mounts made the rear mount feel sloppy. Are there any rear mount inserts or just a rear mount that I can use with the side mounts stock? anyone know places? price? etc?
Wait, you're using stock B-series mounts with your B16 swap? How did you accomplish this? Did you use a welder? Anyways, why not try using that polyurethane goop in the rear mount? Or you coud just buy aftermarket mounts, or maybe just that rear mount.
actually, I have no idea what mounts I am using, but they are stock honda mounts.....
I want to avoid using the polyurethane goop because I don't think it will be stiff enough, my engine rocks back and forth while i stab the gas too quickly or during hard shifts, it sucks....
anyone know any company that sells just the rear mount? or just an insert?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJASPY »</TD></TR><TR><TD CLASS="quote">
No luck with energy suspension stuff? Trust me... that goop WILL stiffen your stock mounts right up! it's polyurethane! The same stuff that they use in aftermarket mounts! It's 5 bucks! try it and see!
not sure, but i believe the old skool weld-in b-series swap method were done using 90-93 DA integra LS mounts. if thats the case, then energy and prothane do make inserts for that mount. maybe you should take a picture of your mount or a 90-93 integra one and compare.
actually since you're in so cal, call up raceline development (http://racelinedevelopment.com) and ask them what rear mount they use. they've done weld-in swaps on EF for years.
acmoc
Mar 29, 2017 05:36 PM
InTheZoneAC
Mar 31, 2014 08:11 AM
